Hello TrueNAS forum!
This is my first post and I would like to ask for some advice on what to do with my 7 disk raidz2 that is constantly getting degraded or faulted.
The server is a used Dell r720xd with 64gb ecc ram and H310 controller. Using TrueNAS Scale latest beta.
I have a 4 disk raid10 running on the server that can scrub with 0 errors.
What I have done is something like this:
1) Created a raidz2 with 5 toshiba and 2 hgst disks and filled it to 70% with data. All old used 4tb disks.
2) Got a few read/write errors on the 2 hgst disks. Also on one of the toshiba disks.
3) Did a scrub. Did a clear. Did a scrub. Did a clear. Errors kept coming back. Short SMART was ok in TrueNAS for all disks.
4) Booted SeaTools and the hgst disks did not allow SMART to test them. Did long generic tests on all disks and they all passed with no errors.
5) Did a scrub and the errors came back on the hgst disks.
6) Swapped the 2 hgst disks for two new WD Red Pro drives.
7) Resilvered and got read/write/checksum errors on the WD Red Pro drives.
8) Cleared the pool. Scrub again, this time I get read/write/checksum errors on the toshiba drive (from step 2).
I am now running SeaTools and doing a long generic test on the WD drives. (Only reads)
I will run a memory test tomorrow.
Could it be that the whole pool is messed up due to disk problems? Maybe I had 3 bad disks from the start...?
Other hardware issue?
Any advice?
Thank you.
Any advice?
Thank you.
