fostersimported
- Jul 25, 2011
Hello All,
I am experiencing the following problem.
Whenever I reboot or shut down my shares are missing on my client pc (XP & windows 7) I cannot see the shares, I also cannot access the share with the direct path. However they are still listed as active shares in the GUI.
The only way to make them available again is to access the GUI and click edit on a share then Ok (i.e re-saving the shares) They are then visible on my client pcs.
This is repeatable every time you shutdown/reboot.
My setup is as follows;
OS Version: FreeBSD 8.2-RELEASE-p2
Platform: AMD Athlon(tm) XP 2400+
Memory: 1007MB
System Time: Sun Jul 31 09:30:02 GMT-1 2011
FreeNAS Build: FreeNAS-8.0.1-BETA4-i386
Volume Path Used Available Size Status
250gb /mnt/250gb 182.8 GiB (89%) 24.7 GiB 225.6 GiB UNKNOWN
500gb /mnt/500gb 392.8 GiB (95%) 22.2 GiB 451.1 GiB UNKNOWN
Also note that my drives have an UNKNOWN Status since BETA4 ( they are UFS formatted)
Another post with the same problem (Link Fixed)
Thanks in advance
Don
Memory: 1007MB
Thanks in advance
Don
