share available on both LAN Port?
vikozo6
Hello
i have updatet my FreeNAS and also done some modification in my Network, i did splitt mein LAN and a created a DMZ.
Both DMZ / LAN have different ip range /24 , FreeNAS with 2 LAN Port each Port has a fix ip in the correct Network.
it is possible to ping each lan port.
so the problem what should be done to have the share also available on both part?
have a nice day
vinc
SweetAndLow
Sweet'NASty
Should be available in both networks by default. Unless you forced it to only bind to one IP. Check your smb settings.
vikozo6
@SweetAndLow
thanks for your feedback, i will check it tonight. maybe this happen because i had one connection defined the share and did add the second connection. hope will find where to check it :rolleyes:
have a nice day
vinc
Services, SMB (or NFS if that's what you're using).
vikozo6
Hello @sretalla & @SweetAndLow
if i go to
services - SMB open edit
i found quiet at the bootem the information
Bind IP Addresses
there a did select both IP Adresse which belongs to the FreeNAS IP Port, so both selected.
Restart SMB did not help
reboot of FreeNAS did also not help
using: FreeNAS-11.2-U4.1
have a nice day
vinc
What isn't working? It really isn't clear what you are trying to do and what happens when it fails.
vikozo6
i can't access my smb share in the Laptop ist in the LAN net
i can access my smb share when the laptop is connected to the DMZ net
some of the share have to be accessible from both side.
have a nice day
vinc
How are you accessing the share from the laptop? (by IP address or by name?)
vikozo6
Normaly it shows up in the Network as device in the file explorer under Network! where i can select the share to go.
SweetAndLow
Sweet'NASty
Can you connect via ip? The just shows up feature is a different thing.
vikozo6
sorry to be later @SweetAndLow
and yes \\ip it works fine
