Shadow Copies TrueNAS 12
Bloodpack
i upgraded today from FreeNAS 11.3-U5 to TrueNAS-12.0-RELEASE
now my shadow copies don´t show up on my Windows machines anymore, i have 4 pools and a bunch of datasets and none of them are showing up
this is one of the datasets
root@truenas[~]# zfs list -t snapshot TANK04/Proxmox-Backups
NAME                                           USED  AVAIL     REFER  MOUNTPOINT
TANK04/Proxmox-Backups@auto-2020-10-23_14-30  53.6G      -      288G  -
TANK04/Proxmox-Backups@auto-2020-10-23_14-45   224K      -      258G  -
TANK04/Proxmox-Backups@auto-2020-10-23_15-00   213K      -      234G  -
root@truenas[~]# testparm -s
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
        aio max threads = 2
        bind interfaces only = Yes
        disable spoolss = Yes
        dns proxy = No
        enable web service discovery = Yes
        interfaces = 127.0.0.1 192.168.178.18
        kernel change notify = No
        load printers = No
        logging = file
        max log size = 51200
        netbios name = FREENAS
        os level = 255
        preferred master = Yes
        registry shares = Yes
        restrict anonymous = 2
        server min protocol = NT1
        server role = standalone server
        server string = TrueNAS Server
        wins support = Yes
        idmap config * : backend = tdb
        directory name cache size = 0
        dos filemode = Yes
[NAS-VM-Backups]
        ea support = No
        path = /mnt/TANK04/Proxmox-Backups
        read only = No
        vfs objects = zfs_space zfsacl streams_xattr
        nfs4:chown = true
Can anyone help me please?
Bloodpack
I have removed the auxiliary parameter from Services and from Sharing and restartet Samba but nothing changed, still no shadow copies.....
*EDIT* Worked after i did a reboot
Thank You!!
