dffvb
 - Apr 14, 2021
Hi there,
I have multiple beginner questions, I dont know whether all in one thread or several threads are prefered?
First question: I have an old Samsung 950 PRO 512 GB – using it as system drive feels a bit wasted, so I was wondering if it is okay to partition it and install to a part thereof? Raid owl made a video on it, so I would follow his approach… or are the road blockas against this?
Second question: BackUp of TrueNAS itself, I know there is the backup option of the conf in the settings, and there are snapshots for pools / datasets. Also too via "Data Protection" I can copy / sync Datasets to external storage. I am wondering whether something like Veeam BackUp Agent for Linux would be of any help? And also backing up VMs, I just set snapshots to be taken on the Dataset regularly right?
Third question: Information gathering – since TrueNAS Scale is sort of new, is there a good overview of best practices etc. where one can pickup information? (other than official documentation) ?
Fourth question: Multi Protocols for the same share (i.e. SMB, WebDAV and Minio) - what are the risks here? Is it bad practice? If yes, why?
Fifth question: Disk settings for SSD only pools - 5 minutes stand by and Advanced Power Management Level 64 okay? Energy Saving features for SSDs anything to pay attention to?
Sixth question: Encryption – whats the best way to encrypt the data, without losing to much performance, and not having to enter the passwords after each reboot? Chose Encryption right at the start when adding a new pool? Or better via SED Password?
Seventh question: Sync settings under "Pool options" - if I add a SLOG device, and have Sync disabled, what happens? Generally where can I read about sync? In standard the client software determines whether it wants to knwo if a sync has been completed, where do I know which client software requests what? In which cases would I want to discabel sync, if I risk losing 5 senonds of data? Where can i read about it?
Many thanks in advance
