Stuart Weaver
- Jul 14, 2014
Hi All, I'm trying to disable a kernel module from loading at boot. I have tried disabling it through the Tunables GUI using a few different combinations and none of them seem to work. While testing I have tried -> Type=Loader Variable=kern.geom.raid.enable Value=0, Type=Loader Variable=hint.geom_raid3.0.disabled Value=1, and Type=Loader Variable=kern.geom.raid3.enable Value=0 - none of them work as expected. Once the machine reboots I can see the tunables are set in the GUI and on the command line using kenv. kldstat show the kernel module was loaded. Any help would be appreciated.
Build FreeNAS-9.3-STABLE-201601181840
Platform Intel(R) Core(TM) i5 CPU M 520 @ 2.40GHz
Memory 1882MB
Memory 1882MB
