setting "copies" property on dataset / volumes - any way from GUI
ezgizza99
hello - I would like to take advantage of the ZFS "copies" property on my datasets, which will make additional copies of the data (automatically prefers separate disks). Anyhow - this is the question - I don't see any way to do this through the freenas 8.3.1 GUI. I can easily do this through the command line, but I am unsure if the property will "stick" after a reboot and reload of the FreeNAS database. Nothing about this ZFS feature is mentioned in the users guide. - thanks
J
James
Guest
Assuming a feature request does not already exist, please add one at support.freenas.org.
AaronLS
Can you clarify if the setting will stick if modified through command line?
paleoN
Yes, of course. The setting is part of the pool itself.
