I'm running freenas 11.3-U3.2. I setup a dedicated replication user following these instructions: https://www.ixsystems.com/documenta...freenas-to-freenas-dedicated-user-replication
They are from a bit of an older version of freenas but the newer versions didn't have a tutorial for creating a dedicated replication user. The issue I am having is that the replication appears to have completed and I can see the dataset on the destination nas (freenas-beta) but I got an email critial failure warning. I pasted it in the code box at the very bottom. It warns that the replication failed.
I granted Repulser user on the freenas-beta the following permissions:
The one error I realized was that the dataset on freenas-alpha is called Media-Storage while the dataset I am copying to on freenas-beta is called alpha-freenas-main. The guide said to make the the same name. Is that the issue?
It looks to me like there is a permission problem with the Repulser user I made. I did not grant the permissions it is complaining are missing because the guide didn't mention them. Also some of the items it complains about are properties and I granted userprop which I thought gave access to all properties. Do I need to modify the permission command to this?
I did create a tunable like the guide explained to do on freenas-beta vfs.usermount set to 1 and using sysctrl. I thought that was supposed to make it mountable so I'm unsure why it is saying it can't mount.
Any help would be greatly appreciated.
zfs allow -ldu Repluser create,destroy,diff,mount,readonly,receive,release,send,userprop, Beta_Pool_1/alpha-freenas-main zfs set readonly=on Beta_Pool_1/alpha-freenas-main
zfs allow -ldu Repluser create,destroy,diff,mount,readonly,receive,release,send,userprop,reservation,refquota,quota,refreservation,aclmode,mount Beta_Pool_1/alpha-freenas-main zfs set readonly=on Beta_Pool_1/alpha-freenas-main
Error full send of pool_1/Media-Storage@custom_snap-2020-06-16_15-13 estimated size is 1.09T full send of pool_1/Media-Storage@custom_snap-2020-06-16_15-13 estimated size is 1.09T cannot receive reservation property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive refquota property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive quota property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive refreservation property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive aclmode property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive copies property on Beta_Pool_1/alpha-freenas-main: permission denied cannot mount 'Beta_Pool_1/alpha-freenas-main': Insufficient privileges. Logs [2020/06/16 15:13:40] INFO [Thread-4] [zettarepl.paramiko.replication_task__task_2] Connected (version 2.0, client OpenSSH_8.0-hpn14v15) [2020/06/16 15:13:40] INFO [Thread-4] [zettarepl.paramiko.replication_task__task_2] Authentication (publickey) successful! [2020/06/16 15:13:41] INFO [replication_task__task_2] [zettarepl.paramiko.replication_task__task_2.sftp] [chan 5] Opened sftp connection (server version 3) [2020/06/16 15:13:41] INFO [replication_task__task_2] [zettarepl.replication.run] For replication task 'task_2': doing push from 'pool_1/Media-Storage' to 'Beta_Pool_1/alpha-freenas-main' of snapshot='custom_snap-2020-06-16_15-13' incremental_base=None receive_resume_token=None [2020/06/16 18:10:50] ERROR [replication_task__task_2] [zettarepl.replication.run] For task 'task_2' unhandled replication error ExecException(1, "full send of pool_1/Media-Storage@custom_snap-2020-06-16_15-13 estimated size is 1.09T\nfull send of pool_1/Media-Storage@custom_snap-2020-06-16_15-13 estimated size is 1.09T\ncannot receive reservation property on Beta_Pool_1/alpha-freenas-main: permission denied\ncannot receive refquota property on Beta_Pool_1/alpha-freenas-main: permission denied\ncannot receive quota property on Beta_Pool_1/alpha-freenas-main: permission denied\ncannot receive refreservation property on Beta_Pool_1/alpha-freenas-main: permission denied\ncannot receive aclmode property on Beta_Pool_1/alpha-freenas-main: permission denied\ncannot receive copies property on Beta_Pool_1/alpha-freenas-main: permission denied\ncannot mount 'Beta_Pool_1/alpha-freenas-main': Insufficient privileges\n") Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/zettarepl/replication/run.py", line 143, in run_replication_tasks run_replication_task_part(replication_task, source_dataset, src_context, dst_context, observer) File "/usr/local/lib/python3.7/site-packages/zettarepl/replication/run.py", line 204, in run_replication_task_part run_replication_steps(step_templates, observer) ... 13 more lines ... raise ExecException(exit_event.returncode, self.output) zettarepl.transport.interface.ExecException: full send of pool_1/Media-Storage@custom_snap-2020-06-16_15-13 estimated size is 1.09T full send of pool_1/Media-Storage@custom_snap-2020-06-16_15-13 estimated size is 1.09T cannot receive reservation property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive refquota property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive quota property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive refreservation property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive aclmode property on Beta_Pool_1/alpha-freenas-main: permission denied cannot receive copies property on Beta_Pool_1/alpha-freenas-main: permission denied cannot mount 'Beta_Pool_1/alpha-freenas-main': Insufficient privileges
