Serviio not working after upgrade to FreeNAS 9.2.1.2
SIL
Serviio has been working fine without any issues up to now.
I upgraded from freeNAS 8.3 to 9.2.1.2.
Upgrade was straight forward and parameter values have been transferred correctly (check OLD FreeNAS 8.3 settings vs. 9.2.1.2 settings).
After I start serviio from FreeNAS shell a ID is displayed BUT nothing else appears to be happening.
Serviio is not shown on the TVs and when trying to start Serviio Console a msg comes up saying that Serviio is not running.
Any ideas.
Thx
Yes.. you have to redo all jails when you upgrade from 8.x to 9.x. The jails from 8.x are not compatible with 9.x
laspo
Hi, I'm currently building my first NAS and was looking for a tutorial on how to install Serviio on FreeNAS 9.x. Deducting from your comments, the installation is similar to installing it on FreeNAS 8.x, correct?
If so, I'll just use a tutorial of the installation on 8.x.
It should be similar, but not necessarily the same.
laspo
Mmh, ok. I'll keep that in mind. If I run in some problems I can't solve myself, I'll ask here. Maybe other people will be struggling with the same thing.
