Krautmaster
- Apr 10, 2017
Dear all,
luckily I just found this thread for Freenas noobs like I am.
Currently all my stuff runs on Server 2019 Datacenter with a X10SDV-4C-7TP4F Supermicro Board, 64Gb ECC Memory, 512GB M2 Disc, 2x256 GB Sata SSD, 4x 14TB WDs, 1x8 TB Backup Disk.
That stuff consumes about 80W-90W all the time, but additionally, it get quite noisy and warm in that server case. And worse, Storace Spaces still kinda sucks, especially parity. I know ZFS is so much better. And id like to shift to a better case and OS.
I was wondering if I can get rid of that config and to startover, maybe with the following:
-> same HW
-> 2x40GB SSD as Mirrored Boot drive conected to the internal SATA headers -> Freenas on
-> 4x14TB HDDs connected to the onboard LSI SAS controller -> RAIDZ1 with compression, maybe dedup
-> 512GB SSD M.2 as L2ARC Cache (can be also a 2 TB SATA SSD which I have in stock)
-> 2x256GB SSDs connected to the onboard LSI SAS controller as write cache (ZIL?)
-> 10Gbe Server <-> Workstation, SCSI / SMB
Required Software on my NAS:
-> PLEX Server
-> Nextcoud Server
-> FileServer
-> VM(s) for webhosting (currently in HyperV: -> Internet -> VirtualFirewall -> NGINX reverse proxy -> 3 VMs with different domains)
(in theory could be all done by wordpress instances without virtualization)
-> Automatic Backup of Nextcloud and Fileserver Files (some, max 8Gb in total) to the additional disk
My Goal:
-> working sw parity. Storage spaces sucks as said
-> maybe hopefully sleeping disks to save power. The SSD caches might prevent them from spinning on each access
-> way higher read and write performance
-> better noise level due to shifting to an existing case (non server case)
What do you experts think? Is this handable my freenas or any other suggestions like eg ESX hypervisior + a seperate VM for freenas and so on?
Thanks and best regards
Krautmaster
-> same HW
-> PLEX Server
-> Nextcoud Server
-> FileServer
My Goal:
Krautmaster
