Self Encrypting Drive (SED) support on TrueNAS SCALE
rockybulwinkle
Does TrueNAS SCALE support SED hard drives? I am trying to source drives for a new zpool and am having trouble finding non-SED drives. Specifically I am considering ST16000NM004G. I don't actually need the SED feature for my use case so it's ok if the drives themselves are supported as long as the SED feature is unused.
I asked a similar question for FreeBSD here: https://forums.freebsd.org/threads/self-encrypting-drive-sed-support.81568/
This is because the pool will initially be created as a backup for an existing pool running on FreeBSD 12.2. Then it will be migrated to a new machine running either TrueNAS CORE or SCALE. CORE appears to support SED in its documentation, but I didn't see anything about that in SCALE's documentation.
Thanks!
Kris Moore
SVP of Engineering
Administrator
By default the SED drives will work on SCALE, don't need to unlock them on to use them as regular devices.
