Seemingly endless resilver
TeKEffect
My server has been resilvering for going on 4 days and it seems to have restarted the process multiple times. When I do a zpool status check everything appears normal. Do I just need to continue waiting or am I missing something?
Thank you for any help
[root@freenas ~]# zpool status -v Volume1
pool: Volume1
state: ONLINE
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Tue Feb 23 01:59:04 2016
285G scanned out of 4.51T at 20.5M/s, 60h3m to go
51.4G resilvered, 6.16% done
NAME STATE READ WRITE CKSUM
Volume1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/5b7041aa-75f3-11e4-a204-bc5ff4e7a6c6 ONLINE 0 0 0
gptid/5c0f2bc4-75f3-11e4-a204-bc5ff4e7a6c6 ONLINE 0 0 0
gptid/5cb4bcbb-75f3-11e4-a204-bc5ff4e7a6c6 ONLINE 0 0 0
gptid/7aaf0f06-d763-11e5-9cd6-bc5ff4e7a6c6 ONLINE 0 0 0 (resilvering)
gptid/5e048309-75f3-11e4-a204-bc5ff4e7a6c6 ONLINE 0 0 0
errors: No known data errors
[root@freenas ~]#
jgreco
Resident Grinch
Please refer to the forum rules, conveniently link at the top of every page in red, which request that you post a hardware manifest and complete description of your system. This information assists us in understanding your circumstances and is much more likely to result in some insight into your problem.
TeKEffect
I'm sorry parts as follows
Motherboard : ASRock E3C226D2I Mini ITX Server Motherboard
Processor: Intel Xeon E3-1220V3 Haswell 3.1GHz 8MB L3 Cache
Memory: 2 X Kingston 8GB 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600
Hard Drive: 5 X WD Red 3TB NAS Desktop Hard Disk Drive
Sounds like you might have another failing drive.
TeKEffect
I think your right I just got this message this morning
CRITICAL: Device: /dev/ada4, ATA error count increased from 0 to 1
It is still again trying to resilver. Should I restart the server or run any kind of diagnostic? Or just let it go thru its paces
note: the drive that is receiving that error is the new one I added to replace a bad drive
Post the output of smartctl -x /dev/adawhatever for all drives. It could be a bad cable, too, and SMART will help narrow it down.
TeKEffect
I'm working now. I will and post the results when I'm home. Thank you for the response
TeKEffect
Here is the report for the drive reporting an error
Device State: Active (0)
Current Temperature: 35 Celsius
Power Cycle Min/Max Temperature: 23/36 Celsius
Lifetime Min/Max Temperature: 23/36 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (8)
Index Estimated Time Temperature Celsius
9 2016-02-24 07:12 ? -
... ..(468 skipped). .. -
0 2016-02-24 15:01 ? -
1 2016-02-24 15:02 23 ****
2 2016-02-24 15:03 34 ***************
3 2016-02-24 15:04 34 ***************
4 2016-02-24 15:05 31 ************
5 2016-02-24 15:06 35 ****************
6 2016-02-24 15:07 32 *************
7 2016-02-24 15:08 36 *****************
8 2016-02-24 15:09 35 ****************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 14 Command failed due to ICRC error
0x0002 2 18688 R_ERR response for data FIS
0x0003 2 18688 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 46669 R_ERR response for non-data FIS
0x0006 2 46609 R_ERR response for device-to-host non-data FIS
0x0007 2 60 R_ERR response for host-to-device non-data FIS
0x0008 2 15758 Device-to-host non-data FIS retries
0x0009 2 38503 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 38495 Device-to-host register FISes sent due to a COMRESET
0x000b 2 55 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 55 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 429180 Vendor specific
That's missing a lot of stuff.
If you're using the webGUI shell, stop doing that and use SSH.
If you decide to ignore the above recommendation, at the very least, pipe the output into less so that you can get the whole output:
smartctl -x /dev/adawhatever | less
TeKEffect
Ok here is the report copied from PuTTy
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68EUZN0
Serial Number: WD-WMC4N0438887
LU WWN Device Id: 5 0014ee 058fbf15b
Firmware Version: 82.00A82
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Feb 25 06:32:11 2016 PST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (40500) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 406) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 100 253 051 - 0
3 Spin_Up_Time POS--K 100 253 021 - 0
4 Start_Stop_Count -O--CK 100 100 000 - 1
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 134
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 1
192 Power-Off_Retract_Count -O--CK 200 200 000 - 0
193 Load_Cycle_Count -O--CK 200 200 000 - 2
194 Temperature_Celsius -O---K 119 113 000 - 31
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 14
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
ATA_READ_LOG_EXT (addr=0x03:0x00, page=0, n=1) failed: Input/output error
Read SMART Extended Comprehensive Error Log failed
SMART Error Log Version: 1
ATA Error Count: 1
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 103 hours (4 days + 7 hours)
ER ST SC SN CL CH DH
10 51 00 18 ab 3f 46 Error: IDNF at LBA = 0x063fab18 = 104835864
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ca 00 00 18 ab 3f 46 08 4d+07:13:21.167 WRITE DMA
ef 02 00 00 00 00 40 00 4d+07:13:21.167 SET FEATURES [Enable write cache]
ef aa 00 00 00 00 40 00 4d+07:13:21.166 SET FEATURES [Enable read look-ahead]
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
SCT Support Level: 1
Current Temperature: 34 Celsius
Temperature History Size (Index): 478 (9)
10 2016-02-24 22:35 ? -
... ..(467 skipped). .. -
0 2016-02-25 06:23 ? -
1 2016-02-25 06:24 23 ****
2 2016-02-25 06:25 34 ***************
3 2016-02-25 06:26 34 ***************
4 2016-02-25 06:27 31 ************
5 2016-02-25 06:28 35 ****************
6 2016-02-25 06:29 32 *************
7 2016-02-25 06:30 36 *****************
8 2016-02-25 06:31 35 ****************
9 2016-02-25 06:32 34 ***************
0x0002 2 18718 R_ERR response for data FIS
0x0003 2 18718 R_ERR response for device-to-host data FIS
0x0005 2 56675 R_ERR response for non-data FIS
0x0006 2 56598 R_ERR response for device-to-host non-data FIS
0x0007 2 77 R_ERR response for host-to-device non-data FIS
0x0008 2 8393 Device-to-host non-data FIS retries
0x0009 2 41163 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 41154 Device-to-host register FISes sent due to a COMRESET
0x000b 2 72 CRC errors within host-to-device FIS
0x0012 2 72 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 484480 Vendor specific
TeKEffect
here is the report for all in txt. It exceeded the char limit for a post
  • AdaALL.txt
Heads up, the file is empty. Also, when posting CLI outputs, please use CODE tags and not QUOTE tags, to preserve formatting.
In any case,...
14 UDMA CRC errors in 134 hours is definitely indicative of interface issues. Mostly bad cabling (including backplanes, if applicable), but it could be something nastier. Definitely start with the simple troubleshooting steps and replace the cable.
TeKEffect
Sorry I had a family emergency yesterday. I replaced the cable right now and after a restart most of the alerts have gone away. I'm going to watch the resilver and see if it improves. Here is the report on the drive with the new cable.
Serial Number:    WD-WMC4N0EAJRL9
LU WWN Device Id: 5 0014ee 604faa554
Local Time is:    Fri Feb 26 16:36:51 2016 PST
ATA Security is:  Disabled, frozen [SEC2]
                                        was never started.
                                        been run.
data collection:                (40860) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 410) minutes.
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   243   182   021    -    2841
  4 Start_Stop_Count        -O--CK   100   100   000    -    22
  7 Seek_Error_Rate         -OSR-K   100   253   000    -    0
  9 Power_On_Hours          -O--CK   086   086   000    -    10844
12 Power_Cycle_Count       -O--CK   100   100   000    -    22
192 Power-Off_Retract_Count -O--CK   200   200   000    -    16
193 Load_Cycle_Count        -O--CK   200   200   000    -    179
194 Temperature_Celsius     -O---K   122   097   000    -    28
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
Current Temperature:                    28 Celsius
Power Cycle Min/Max Temperature:     25/28 Celsius
Lifetime    Min/Max Temperature:      2/53 Celsius
Temperature History Size (Index):    478 (109)
110    2016-02-26 08:39    35  ****************
...    ..( 52 skipped).    ..  ****************
163    2016-02-26 09:32    35  ****************
164    2016-02-26 09:33    34  ***************
...    ..( 39 skipped).    ..  ***************
204    2016-02-26 10:13    34  ***************
205    2016-02-26 10:14    33  **************
...    ..( 46 skipped).    ..  **************
252    2016-02-26 11:01    33  **************
253    2016-02-26 11:02    32  *************
...    ..(297 skipped).    ..  *************
  73    2016-02-26 16:00    32  *************
  74    2016-02-26 16:01     ?  -
  75    2016-02-26 16:02    25  ******
  76    2016-02-26 16:03    25  ******
  77    2016-02-26 16:04    26  *******
  78    2016-02-26 16:05    27  ********
  79    2016-02-26 16:06    27  ********
  80    2016-02-26 16:07    27  ********
  81    2016-02-26 16:08    28  *********
  82    2016-02-26 16:09    35  ****************
...    ..(  7 skipped).    ..  ****************
  90    2016-02-26 16:17    35  ****************
  91    2016-02-26 16:18    34  ***************
...    ..( 13 skipped).    ..  ***************
105    2016-02-26 16:32    34  ***************
106    2016-02-26 16:33    35  ****************
...    ..(  2 skipped).    ..  ****************
109    2016-02-26 16:36    35  ****************
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            2  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4          442  Vendor specific
[root@freenas] ~#
TeKEffect
Resilver completed!
I am getting this error though
CRITICAL: The volume Volume1 (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
Robert Trevellyan
Pony Wrangler
To have a chance of helping, we need the smartctl output for all your drives. The file you posted before was empty.
Robert Trevellyan
Pony Wrangler
I don't much like the look of ada1, but I think the error report was probably caused by ada4 (the new drive). Whether the source is the drive, or something else, is not obvious to me. Are all drives connected to the same controller?
EDIT: your drives are getting cooked at 53C.
TeKEffect
They are all connected to the same controller
I have them in a Lian Li PC-Q25B Mini ITX case. I'll try to figure out a creative cooling solution
TeKEffect
Just to update anyone watching the thread. After replacing the cables and a couple restarts everything is working perfectly. Thanks for the help. The last thing I would have have suspected was a cable
