security run output.
Cougar014
Is there someone willing to take a look at my security run output?
I dont understand it completely and i am wondering if there is something odd/wrong.
Also i want to learn from it so i can do it myself next time.
I am surprised that it is such a long output and because of the double uptime message i have the feeling it rebooted twice during the night. But i dont get why....
Thanks in advance !
because it is has more then 30.000 characters I am not allowed to put it in one single message. So i've added a PDF
thanks in advance
  • Freenas security log.pdf
D
dlavigne
Guest
Looks like the system rebooted and you have a jail or plugin installed.
Cougar014
Thanks for your answer.
I indeed "have" a jail.
I was trying to install an OpenVPN jail yesterday. But that wasnt a succes.
So I should have an empty jail, yes.
But why is it rebooting?! Twice! I haven't setup something like an auto reboot or something.
So I was looking for something odd, but I couldn't find it.
D
dlavigne
Guest
Might be a heat issue. This is interesting from your log:
> coretemp0: <CPU On-Die Thermal Sensors> on cpu0
> coretemp0: Tj(target) value 0 does not seem right.
> coretemp1: <CPU On-Die Thermal Sensors> on cpu1
> coretemp1: Tj(target) value 0 does not seem right.
> coretemp2: <CPU On-Die Thermal Sensors> on cpu2
> coretemp2: Tj(target) value 0 does not seem right.
> coretemp3: <CPU On-Die Thermal Sensors> on cpu3
> coretemp3: Tj(target) value 0 does not seem right.
Cougar014
Ok, strange. I have a stock Intel cpu with stock cooler.
Luckily it isn't showing some high numbers.... but I will try to take a look into it when I have time
Thanks!
