Hellrazorx
- Apr 30, 2021
HI,
We've been using Truenas AD integration for several year now. Everything worked fine so far but now we want to de deploy a new file server under the same Domain.
I can successfully join the domain with the second Truenas Server (TN2):
- I'm Using the same ''user'' as principal to join the domain
- This second server is under another VLAN
(just saying)
Once TN2 joined the domain, everything works fine on TN2.
But while authenticated users can still access the file server on TN1, new users cannot. It displays the error message
``` You might not have permission to use this network resource. Contact the Administrator to find out if you have access permissions. ```
TN1 is in production so I reverted everything back to where it was before by Leaving Domain on TN2 and TN1, then rejoin the domain on TN1. Auth behaviors came back to normal on the users side.
I'm checking with you guys first before trying to virtualize the whole thing and simulate this behavior.
Is it possible I'd need to:
- Create a specific principal for each Truenas servers? Avoiding using the same one for both?
- Exploring a Identification conflict: Should I configure something else than the Network Hostname to avoid a domain join conflict?
Thanks for your input
(just saying)
