Second build validation
George51
So - I have got myself hooked on FreeNAS, and currently looking for a bit of an upgrade - I am a while off pulling the trigger, but what to start sourcing what I want and checking that it will all work (hopefully) flawlessly.
I'm looking at currently:
Motherboard: X10DRH-iT
Chasis: SC826BA-R920LPB
HBA: M1015 (Low profile, flashed to IT mode)
RAM: Undecided - probably 4x 16 gb 2133 ECC
CPU: Undecided, but 2 x a E5-2600v3
SATADOM: 2 x mirrored for boot. (Board has two powered ports)
The aim is to have 2 x RAIDz2 vdevs, with 6 drives in each, with 10GBase-T ports. I did initially look at a chasis with a SAS3 backplane, and therefore the board with the onboard LSI 3108. But as I will only be using mechanical disks, and support for SAS3 is flakely currently, I assumed it would best to avoid?
I want the whole thing to be very upgradeable - so 16 RAM slots is ideal, as I can keep adding RAM as I want. That was also why I started with the SAS3 stuff.
So questions I have:
With the M1015 its got two SFF-8087 ports, the backplane on the chasis has 3x SFF-8087 ports, and as I understand it, each port is good for 4 HDD's? So does that mean I need two M1015's for 12 HDD's? Using three SFF-8087 cables?
Also would I have to flash/check/change the firmware on that backplane? Or as long as I put the M1015 into IT mode, that will be the drives good to go?
Cheers
depasseg
FreeNAS Replicant
What model backplane? I think you are confusing channels and drives. Each channel can support multiple drives. And the backplanes usually have an "outgoing" port to support daisy-chaining drive chassis.
Look at appendix E:
http://www.supermicro.com/manuals/chassis/2U/SC826.pdf
ALFA
Wow, almost what I have in mind. Only one word of avise, stay away from the LSI 3108 (or any SAS-3 controller), I think is not well supported by FreeNas or at least is not very stable at the moment and there are some issues with the backward compatibility (SAS3 cards connect to a SAS2 backplanes) too, and from what I hear one time from Ericloewe is that it's not worth it unless you have a bunch of SSD. Beside I think that if you want some benefits from it you need some 12 Gb/s enterprise hdd (until you get bottleneck by your Gigabit LAN) and that are a lot of cash, but that is my opinion.
Kind regards.
George51
Look at appendix E:
I may well be - I was under the impression each port from the M1015 could connect to 4 hard drives, so I guess one channel per 4 drives?
2U Direct Attached Backplane, features:
• Up to 6Gb support
• SES-2 Enclosure Management Support
• SAS/SATA support
• Three SFF 8087 connectors
That is what supermicro has to say about the backplane, I assume I need to connect all three connectors... And as Lordadmrial Drake said, means I will need two M1015's, or a card with four ports, any recommendations on a 4 port card?
Marbus90 thats certainly worth looking at, aim is to be entirely future proof, I do maybe 4 transcodes now, but I want more capability, and with adding a second vdev, more RAM and another CPU is certainly over kill but its what I'm looking for going forward.
marbus90
depasseg was describing expander backplanes.
If you want that much future-proofness by a factor of 2-3x, go for a Supermicro 846E16 or 847BE16 with 2x Xeon E5-2643 v3. Don't forget to grab a board with 24 DIMM slots and use only 8x32GB LRDIMMs from the start, upgrade to 24x32GB DIMMs later on.
It'll still look old and slow in 3 years.
George51
Okay, okay point taken. For my use however it will be future proof to a certain extent. Any "FreeNAS recommended" cards instead of the M1015 that have four ports? Or is getting two of those the best way to go?
There are no good 4-port controllers, hence we don't have any in the recommended hardware list. :P
marbus90
Get a chassis with an expander backplane, use 1 8port SAS for all 12 drives or connect the 4 other bays to the Intel SATA ports. 16port controllers use more energy than 2 8port controllers and are more expensive. If you want to do plex transcoding, that's where futureproofing starts. 6 transcodes max? E5-1650 v3 does the needful. With only 12 HDDs and archival/cold storage (I don't think you'll be running VMs off there with 2 raidz2 vdevs) you won't need that much RAM anyway.
Alternative HBAs are LSI 9211, LSI 9207 and Supermicro AOC-S2308L-L8e
While 8 lanes/2ports is the go-to thing, there are acceptable 4lane/1port and 16lane/4port cards. Just not that preferable, available and cost-effective. ;)
There are no good 4-port controllers, hence we don't have any in the recommended hardware list. :p
The good four-port controllers are actually the very same LSI SAS 2008s and 2308s, but with only four channels connected, instead of all eight. So yeah, no good choices there.
