Help changing from 16bay rack to PC Chassis
JibbaJabba
Morning All!
Currently my 16bay rack server is sitting under my kids room and humming like a W***E...
Just purchased a Coolmaster HAF 935 chassis whic h is awesome.
The main reason for change is the dam sound, so loud. :)
Currently the supermicro 4u chassis has a backplane connected to the m1015.
Can i take the Mobo, ram, cpu, m1015 and Transplant it into the Coolmaster chasis?
If so, will i lose my data? do i have to arrange the hdd's back exactly as they were numbered before?
H.E.L.P - Going crazy :)
depasseg
FreeNAS Replicant
Drive order doesn't matter. As long as you were using the M1015 in IT mode, you should be fine moving them over in any order.
JibbaJabba
Thanks! Tried it today...no luck. Dam 650w psu wouldnt power the supermicro motherboard....fans came on and that's about it.
*sigh* so close
