Sonicmixmaster
- Feb 20, 2022
Please skip to the next post. I deleted the contents of this one as I had several screw ups.
notifications_active CRITICAL Device: /dev/da3 [SAT], ATA error count increased from 32 to 33. 08/14/2021 01:05:50 PM (America/New_York) Dismiss notifications_active CRITICAL Device: /dev/da3 [SAT], ATA error count increased from 33 to 34. 02/20/2022 12:54:54 AM (America/New_York) Dismiss
Last login: Sun Feb 20 16:04:06 on pts/6 FreeBSD 12.2-RELEASE-p12 ec84e0c52a1(HEAD) TRUENAS TrueNAS (c) 2009-2022, iXsystems, Inc. All rights reserved. TrueNAS code is released under the modified BSD license with some files copyrighted by (c) iXsystems, Inc. For more information, documentation, help or support, go here: http://truenas.com Welcome to TrueNAS Warning: settings changed through the CLI are not written to the configuration database and will be reset on reboot. root@truenas[~]# smartctl -a /dev/da3 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p12 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD140EDFZ-11A0VA0 Serial Number: ######## LU WWN Device Id: 5 000cca 28fc16a23 Firmware Version: 81.00A81 User Capacity: 14,000,519,643,136 bytes [14.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Feb 20 16:11:23 2022 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1475) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0 2 Throughput_Performance 0x0004 135 135 054 Old_age Offline - 112 3 Spin_Up_Time 0x0007 081 081 001 Pre-fail Always - 391 (Average 389) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 97 5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0 7 Seek_Error_Rate 0x000a 100 100 001 Old_age Always - 0 8 Seek_Time_Performance 0x0004 133 133 020 Old_age Offline - 18 9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 10658 10 Spin_Retry_Count 0x0012 100 100 001 Old_age Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 97 22 Unknown_Attribute 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 533 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 533 194 Temperature_Celsius 0x0002 048 048 000 Old_age Always - 34 (Min/Max 18/52) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 38 SMART Error Log Version: 1 ATA Error Count: 38 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 38 occurred at disk power-on lifetime: 10650 hours (443 days + 18 hours) When the command that caused the error occurred, the device was doing SMART Offline or Self-test. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 48 a5 b4 40 00 2d+07:26:54.382 READ FPDMA QUEUED 60 40 00 08 a5 b4 40 00 2d+07:26:54.381 READ FPDMA QUEUED 60 40 08 c8 a4 b4 40 00 2d+07:26:54.381 READ FPDMA QUEUED 60 40 00 88 a4 b4 40 00 2d+07:26:54.381 READ FPDMA QUEUED 60 40 08 48 a4 b4 40 00 2d+07:26:54.381 READ FPDMA QUEUED Error 37 occurred at disk power-on lifetime: 10649 hours (443 days + 17 hours) When the command that caused the error occurred, the device was doing SMART Offline or Self-test. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 80 00 30 b0 64 40 00 2d+06:21:04.778 READ FPDMA QUEUED 60 40 18 70 b5 64 40 00 2d+06:21:04.778 READ FPDMA QUEUED 60 40 10 30 b5 64 40 00 2d+06:21:04.778 READ FPDMA QUEUED 60 80 08 b0 b4 64 40 00 2d+06:21:04.778 READ FPDMA QUEUED 60 40 10 f0 af 64 40 00 2d+06:21:04.778 READ FPDMA QUEUED Error 36 occurred at disk power-on lifetime: 10649 hours (443 days + 17 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 80 00 50 2c fc 40 00 2d+05:59:41.784 READ FPDMA QUEUED 60 40 18 50 32 fc 40 00 2d+05:59:41.782 READ FPDMA QUEUED 60 40 10 10 32 fc 40 00 2d+05:59:41.782 READ FPDMA QUEUED 60 40 08 d0 31 fc 40 00 2d+05:59:41.782 READ FPDMA QUEUED 60 00 38 50 24 fc 40 00 2d+05:59:41.761 READ FPDMA QUEUED Error 35 occurred at disk power-on lifetime: 10645 hours (443 days + 13 hours) When the command that caused the error occurred, the device was doing SMART Offline or Self-test. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 80 21 40 40 00 2d+02:29:17.285 READ FPDMA QUEUED 60 40 10 40 21 40 40 00 2d+02:29:17.270 READ FPDMA QUEUED 60 40 00 00 21 40 40 00 2d+02:29:17.270 READ FPDMA QUEUED 60 80 08 80 20 40 40 00 2d+02:29:17.266 READ FPDMA QUEUED 60 80 00 80 75 3d 40 00 2d+02:29:17.266 READ FPDMA QUEUED Error 34 occurred at disk power-on lifetime: 10644 hours (443 days + 12 hours) When the command that caused the error occurred, the device was doing SMART Offline or Self-test. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 84 41 00 00 00 00 00 Error: ICRC, ABRT at LBA = 0x00000000 = 0 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 80 00 20 cc 07 40 00 2d+01:14:35.835 READ FPDMA QUEUED 60 40 08 e0 cb 07 40 00 2d+01:14:35.834 READ FPDMA QUEUED 60 40 00 a0 cb 07 40 00 2d+01:14:35.834 READ FPDMA QUEUED 60 40 00 60 cb 07 40 00 2d+01:14:35.834 READ FPDMA QUEUED 60 c0 08 a0 ca 07 40 00 2d+01:14:35.830 READ FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 10651 - # 2 Short offline Completed without error 00% 10645 - # 3 Short offline Completed without error 00% 10481 - # 4 Short offline Completed without error 00% 10476 - # 5 Short offline Completed without error 00% 10313 - # 6 Short offline Completed without error 00% 10308 - # 7 Short offline Completed without error 00% 10145 - # 8 Short offline Completed without error 00% 10140 - # 9 Short offline Completed without error 00% 9977 - #10 Short offline Completed without error 00% 9810 - #11 Short offline Completed without error 00% 9641 - #12 Short offline Completed without error 00% 9473 - #13 Short offline Completed without error 00% 9305 - #14 Short offline Completed without error 00% 9137 - #15 Short offline Completed without error 00% 8969 - #16 Short offline Completed without error 00% 8801 - #17 Short offline Completed without error 00% 8633 - #18 Short offline Completed without error 00% 8465 - #19 Short offline Completed without error 00% 8297 - #20 Short offline Completed without error 00% 8132 - #21 Short offline Completed without error 00% 7961 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0
selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. root@truenas[~]# smartctl -a /dev/da2 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p12 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: WDC WD140EDFZ-11A0VA0 Serial Number: ######## LU WWN Device Id: 5 000cca 28fc177a6 Firmware Version: 81.00A81 User Capacity: 14,000,519,643,136 bytes [14.0 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Form Factor: 3.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Sun Feb 20 15:28:02 2022 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 101) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: (1534) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0 2 Throughput_Performance 0x0004 135 135 054 Old_age Offline - 108 3 Spin_Up_Time 0x0007 081 081 001 Pre-fail Always - 394 (Average 391) 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 93 5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0 7 Seek_Error_Rate 0x000a 100 100 001 Old_age Always - 0 8 Seek_Time_Performance 0x0004 133 133 020 Old_age Offline - 18 9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 10658 10 Spin_Retry_Count 0x0012 100 100 001 Old_age Always - 0 12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 93 22 Unknown_Attribute 0x0023 100 100 025 Pre-fail Always - 100 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 529 193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 529 194 Temperature_Celsius 0x0002 045 045 000 Old_age Always - 36 (Min/Max 19/53) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 10651 - # 2 Short offline Completed without error 00% 10646 - # 3 Short offline Completed without error 00% 10481 - # 4 Short offline Completed without error 00% 10476 - # 5 Short offline Completed without error 00% 10313 - # 6 Short offline Completed without error 00% 10308 - # 7 Short offline Completed without error 00% 10145 - # 8 Short offline Completed without error 00% 10140 - # 9 Short offline Completed without error 00% 9977 - #10 Short offline Completed without error 00% 9811 - #11 Short offline Completed without error 00% 9641 - #12 Short offline Completed without error 00% 9473 - #13 Short offline Completed without error 00% 9305 - #14 Short offline Completed without error 00% 9137 - #15 Short offline Completed without error 00% 8970 - #16 Short offline Completed without error 00% 8801 - #17 Short offline Completed without error 00% 8633 - #18 Short offline Completed without error 00% 8465 - #19 Short offline Completed without error 00% 8297 - #20 Short offline Completed without error 00% 8132 - #21 Short offline Completed without error 00% 7961 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, r
Forum rules require as much info as possible so I added a lot. I dont know what else to tell you without repeating what I already said in the post above yours.Maybe it is too late here, but I really don't understand what the problem or question is. It would be helpful not to put pretty much everything in one large paragraph, but structure things and highlight was it is that you want, and what the relevant background information is.
Thanks for the reply. If it's CRC then that is not a major problem and I'm happy. If I just move the cables around to different drives is that possible? For example if I put the cable from drive 3 to 2 and 2 to 3 is that going to mess up the array? I would like to see if drive 2 will start throwing errors in the future. I read somewhere that drives can be reinstalled in any order and the software will find them no matter how they are plugged in. Is that true? As far as the PSU I think a 850W will have a longer life as it wont be as loaded as the 550W because I am planning on running this 24/7 as it has been for over a year now. I could use the 550W for other project that is not as demanding in the future.Well, it's useful to have the questions visually stand out, which they tend not to in your post. It helps to understand what is going on.
In any case, the most relevant piece of information is that the drive reporting errors is reporting CRC errors. So, something along the transmission line is in poor shape - most likely the cables. All other SMART values look okay.
I think the PSU replacement was premature, in this case, and that you need to try out different (shorter, if possible) SATA cables. Or cable, singular, specifically for the affected disk.
Two answers:f I just move the cables around to different drives is that possible? For example if I put the cable from drive 3 to 2 and 2 to 3 is that going to mess up the array?
For abundance of clarity, yes.I read somewhere that drives can be reinstalled in any order and the software will find them no matter how they are plugged in. Is that true?
The 550 W unit is a good size for this system, so I would not worry about it. Nothing wrong with the larger unit. Good news is that Seasonic's modular cables have been fully-interchangeable for maybe a decade now, so you can just swap out those two PSUs without a care in the world.*As far as the PSU I think a 850W will have a longer life as it wont be as loaded as the 550W because I am planning on running this 24/7 as it has been for over a year now.
Thank you for your help. My power supply arrived, now I just need to take some time and swap it out. I am using these cables on the LSI HBA https://www.amazon.com/gp/product/B01BTEYLEQ do you think these are good enough? I have a big case so these are 3.3 feet and are comfortably the right size for where my drives are placed.Two answers:
- ZFS, like any self-respecting, vaguely-useful RAID-adjacent solution, does not care about which disk goes where, as long as it can see the disk and talk to it,
- If you're going to do that, make sure to scrub the pool first, wouldn't want to do that sort of maneuver with silent corruption and risk spreading it to another disk.
* Definitely care about this. Not everyone has such a long history of interchangeable cables. Corsair comes close, but their situation is trickier.
Drive failure would rather manifest at items #5, 196, 197, 198.Thanks for the reply. If it's CRC then that is not a major problem and I'm happy. If I just move the cables around to different drives is that possible?
