SCSI Error
djr123
Serial ATA Drives, 2 Multiplexers.
The errors are happening less frequently, but persist nonetheless.
Any ideas?
bahne
I have something similar, it's a SCSI check as well although i think mine is the CDROM, it goes through this same check about 10 times and then goes on booting up. I'm trying to find out if this is something that can be disabled, if its some kind of checkdisk command that can be unflagged. It puts a few extra minutes onto the bootup sequence which is not much but still annoying
