Hi all
With the success and reliability of two boxes running FreeNAS for a few years (4 or 5) on Atom based PC's with 2GB RAM, I decided to build another box based on another Small Form Factor, and got an HP N54L 2.2Ghz Turion CPU, with 16GB RAM and 5 x 3 TB Seagate Barracuda 7200 drives.
Assembled the machine and installed FreeNAS 9.2.17 and created a RAIDZ1 and a single Pool, about a month ago, accepting all the defaults.
I then began transferring some large ISO's (DVD's) from one of the other machines, using rsync, and the machine has about 3 TB used.
Last week the machine became sluggish and hanged for extended periods (minutes), causing extremely slow transfer rates.
I decided to shutdown and investigate.
So first thing was to run a scrub from the command line. I'm surprised because it began scrubbing and the ETA to complete (zpool status POOL) was more than 190 hours.....
It kept giving that estimate until about 10% of progress and then it got some turbo speed and went from 10% completion to 95% completion in less than 24h, when it began to slow down again dramatically, and now the status is pictured below.
As you can see, it doesn't even try to do an estimate to completion (scan is slow, no estimated time) and the percentage done is already above 100% !!!!
Any ideas of what might be happening here ??? I'll let it go until the scrub stops but would like to get some clues to prevent if I did something wrong.
TIA
TIA
