Stux
- Jun 2, 2016
@SweetAndLow nailed it.
To give an idea how critical the top cover is in a rack mount case like this:
https://forums.freenas.org/index.ph...o-x10-sri-f-xeon-e5-1650v4.46262/#post-315996
That seems like a reasonable next troubleshooting step. Do you have enough slots to do a inplace replacement? This way you don't have to put your pool into a degraded state.so far another read error on a second drive. thus far both are the same drives from the last scrub. da 35 and da36. da 36 just gave the error and is at 23c. If this scrub goes the same as the last, the same 3rd drive will error soon. I have 2 unused reds I can swap in 1 at a time to replace 2 of these 3 drives and scrub again.
The problem vdev is part of the only pool I run. 1 pool, 5 vdevs of 8. Dual psu's in the supermicro case. 1200 watt psus attached to the stock backplane.Is your vdev the sole vdev in its pool?
If so, have you tried recreating the vdev?
Sounds like you really have done everything right :-/
How are the drives powered?
Then unfortunately you can't move it out of the system without destroying the pool.The problem vdev is part of the only pool I run
I simply meant physically isolating the vdev on its own chassis whilst still functioning as a vdev of the poolThen unfortunately you can't move it out of the system without destroying the pool.
I don't know how we can figure that out. I've thought it possible there was "bad data" or some fragmented something or other causing this issue for some time now. I've swapped so many drives and cases and cables trying to track this issue down. Each and every scrub there are read errors on 2-4 drives and on average 800k bits repaired during the scrub.After all this hardware shenanigans. Is it possible the issue is actually with the vdev rather than the devices?
smartctl -x | grep Lifetime
.Thats a cool command, lifetime high temp of da36 is 46c.smartctl -x | grep Lifetime
