- Aug 16, 2011
Yeah, maybe you are. Compare your process to:WOW seems like a lot of work maybe I'm missing something.
- Download script
- Write config file of a half-dozen lines
- Run script
JAIL_IP="10.0.0.14" DEFAULT_GW_IP="10.0.0.1" INTERFACE="lagg0" POOL_PATH="/mnt/MyVolume" JAIL_NAME="nextcloud" TIME_ZONE="Europe/Rome" # See http://php.net/manual/en/timezones.php HOST_NAME="nc.soon.it" STANDALONE_CERT=1 DNS_CERT=0 TEST_CERT="--test"
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:c4:7a:e2:05:12 hwaddr 0c:c4:7a:e2:05:12 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active igb1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:c4:7a:e2:05:12 hwaddr 0c:c4:7a:e2:05:13 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> groups: lo lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6> ether 0c:c4:7a:e2:05:12 inet 10.0.0.11 netmask 0xffffff00 broadcast 10.0.0.255 inet 10.0.0.14 netmask 0xffffff00 broadcast 10.0.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet autoselect status: active groups: lagg laggproto lacp lagghash l2,l3,l4 laggport: igb0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> laggport: igb1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:c0:ec:4f:a7:00 nd6 options=1<PERFORMNUD> groups: bridge id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair2a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 8 priority 128 path cost 2000 member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 7 priority 128 path cost 2000 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 6 priority 128 path cost 2000 member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 4 priority 128 path cost 10000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ee:50:00:06:0a hwaddr 02:ee:50:00:06:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ee:50:00:07:0a hwaddr 02:ee:50:00:07:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair epair2a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:ee:50:00:08:0a hwaddr 02:ee:50:00:08:0a nd6 options=1<PERFORMNUD> media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active groups: epair
[Sun May 27 18:22:31 CEST 2018] Using stage ACME_DIRECTORY: https://acme-staging.api.letsencrypt.org/directory [Sun May 27 18:22:31 CEST 2018] Standalone mode. netstat: kvm not available: /dev/mem: No such file or directory [Sun May 27 18:22:32 CEST 2018] Registering account [Sun May 27 18:22:33 CEST 2018] Registered [Sun May 27 18:22:33 CEST 2018] ACCOUNT_THUMBPRINT='167M4d3F8em-znrB1qcpxaK8Kuk_IlKhzOT4yENEbx8' [Sun May 27 18:22:33 CEST 2018] Creating domain key [Sun May 27 18:22:33 CEST 2018] The domain key is here: /root/.acme.sh/nc.soon.it/nc.soon.it.key [Sun May 27 18:22:33 CEST 2018] Single domain='nc.soon.it' [Sun May 27 18:22:33 CEST 2018] Getting domain auth token for each domain [Sun May 27 18:22:33 CEST 2018] Getting webroot for domain='nc.soon.it' [Sun May 27 18:22:33 CEST 2018] Getting new-authz for domain='nc.soon.it' [Sun May 27 18:22:34 CEST 2018] The new-authz request is ok. [Sun May 27 18:22:34 CEST 2018] Verifying:nc.soon.it [Sun May 27 18:22:34 CEST 2018] Standalone mode server [Sun May 27 18:22:39 CEST 2018] Pending [Sun May 27 18:22:41 CEST 2018] Pending [Sun May 27 18:22:43 CEST 2018] Pending [Sun May 27 18:22:46 CEST 2018] Pending [Sun May 27 18:22:48 CEST 2018] nc.soon.it:Verify error:Fetching http://nc.soon.it/.well-known/acme-challenge/FKACG8-vI4u70BAFlN7GSyVkT8sxR2aiVMkyvz5AOXk: Timeout during connect (likely firewall problem) [Sun May 27 18:22:48 CEST 2018] Please add '--debug' or '--log' to check more details. [Sun May 27 18:22:48 CEST 2018] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh True * Stopping nextcloud + Running prestop OK + Stopping services OK + Removing jail process OK + Running poststop OK * Starting nextcloud + Started OK + Starting services OK [Sun May 27 18:23:30 CEST 2018] Using stage ACME_DIRECTORY: https://acme-staging.api.letsencrypt.org/directory [Sun May 27 18:23:31 CEST 2018] Single domain='nc.soon.it' [Sun May 27 18:23:31 CEST 2018] Getting domain auth token for each domain [Sun May 27 18:23:31 CEST 2018] Getting webroot for domain='nc.soon.it' [Sun May 27 18:23:31 CEST 2018] Getting new-authz for domain='nc.soon.it' [Sun May 27 18:23:32 CEST 2018] The new-authz request is ok. [Sun May 27 18:23:32 CEST 2018] Verifying:nc.soon.it [Sun May 27 18:23:35 CEST 2018] Pending [Sun May 27 18:23:37 CEST 2018] Pending [Sun May 27 18:23:40 CEST 2018] Pending [Sun May 27 18:23:42 CEST 2018] Pending [Sun May 27 18:23:44 CEST 2018] nc.soon.it:Verify error:Fetching http://nc.soon.it/.well-known/acme-challenge/ylJ3kG4UsGdVXP_WjfbPSYKdc2_Did77QKmGd6VdIyU: Timeout during connect (likely firewall problem) [Sun May 27 18:23:44 CEST 2018] Please add '--debug' or '--log' to check more details. [Sun May 27 18:23:44 CEST 2018] See: https://github.com/Neilpang/acme.sh/wiki/How-to-debug-acme.sh True Nextcloud is not installed - only a limited number of commands are available Nextcloud was successfully installed System config value logtimezone set to string Europe/Rome System config value log_type set to string file System config value logfile set to string /var/log/nextcloud.log System config value loglevel set to string 2 System config value logrotate_size set to string 104847600 System config value memcache.local set to string \OC\Memcache\APCu System config value redis => host set to string /tmp/redis.sock System config value redis => port set to integer 0 System config value memcache.locking set to string \OC\Memcache\Redis System config value htaccess.RewriteBase set to string / .htaccess has been updated System config value trusted_domains => 1 set to string nc.soon.it System config value trusted_domains => 2 set to string 10.0.0.14 encryption enabled Encryption enabled Default module: OC_DEFAULT_MODULE Encryption disabled Set mode for background jobs to 'cron' Successfully removed mount from nextcloud's fstab Installation complete! Using your web browser, go to https://nc.soon.it to log in Default user is admin, password is NeKcRNha3CfLhsGW Database Information -------------------- Database user = nextcloud Database password = uwMpPhBJWxuYZARbhxC/jA== The MariaDB root password is 8/pT5uK23ijv1ejxGDEQRQ== All passwords are saved in /root/db_password.txt
I'd expect so, since you gave lagg0 as your interface.I noticed that the IP address I set in the config file (10.0.0.14) was added to the network interface lagg0. Is that how it's supposed to be?
Yes, that would be the (or at least "a") reason*. That's the reason that acme.sh runs in standalone mode the first time it tries to obtain a cert--it spins up its own mini-web server for validation purposes. @dureal99d, whose how-to I used as a starting point, has you spin up the web server, get the cert, then update the server's configuration to use that cert, which is significantly more complicated to script--but it would end up making troubleshooting a bit easier.Yet, https://www.grc.com/x/ne.dll?rh1dkyd2 reports that port 80 is not open. Perhaps because the web server hasn't been deployed?
service apache24 start). If that runs without errors, try a few tests:No. Let's Encrypt have repeatedly stated their intent to validate from a wide range of IP addresses and geographical locations, so at least at the time of cert issuance or renewal, the whole world needs to be able to connect on port 80. If that isn't acceptable, look into using DNS validation--many DNS hosts have supported APIs, and then you could set your firewall however you wanted.do you think that whitelisting the Letsencrypt.org IP address (23.12.99.165) would be enough?
It's hard to say. In my own experience, ISPs who block port 80 won't generally unblock it just because the customer asks them to; they make you upgrade to a more-expensive account (which is why I have business-class Internet service at my home). In any event, port 23 is meaningless, and there's no reason you should want it open (other than that you don't want your ISP blocking anything).Discovered that my isp blocks 80. 443 and 23 after that. I disabled that protection and yet, I can not reach my jail from the outside world, only from inside my lan. Do you think it needs some time before the change comes trough?
acme.sh --issue -d ${HOST_NAME} -w /usr/local/www/apache24/data -k 4096 --fullchain-file /usr/local/etc/pki/tls/certs/fullchain.pem --key-file /usr/local/etc/pki/tls/private/privkey.pem --reloadcmd "service apache24 reload" ${HOST_NAME}; you'd replace that with your FQDN.Go to https://www.sslchecker.com/csr/self_signed and generate a self-signed cert for your hostname (nc.soon.it). Place the certificate in your jail at /usr/local/etc/pki/tls/certs/fullchain.pem, and the private key at /usr/local/etc/pki/tls/private/privkey.pem.
You need to run this command using the jail's shell, not the FreeNAS shell. Doroot@server:/mnt/iocage/jails/nextcloud/root # service apache24 start
iocage console nextcloud, then try again.Strange that it didn't give any further indication of the error (edit: you might find more in /var/log/httpd-error.log). Did you put the cert files in the jail, or in the base FreeNAS system? They should be in the jail./usr/local/etc/rc.d/apache24: WARNING: failed to start apache24
iocage destroy nextcloud rm -r /tmp directory created to download git repository from the previous installation mkdir /tmp and navigated to cd /tmp directory git clone https://github.com/danb35/freenas-iocage-nextcloud cd freenas-iocage-nextcloud nano nextcloud-config and provided appropriate info as per previous instructions ./nextcloud-jail.sh iocage console nextcloud nano /usr/local/etc/pki/tls/certs/fullchain.pem nano /usr/local/etc/pki/tls/private/privkey.pem service apache24 start [Sat Jun 02 12:32:17.032022 2018] [mpm_event:notice] [pid 23626:tid 34397577216] AH00491: caught SIGTERM, $
[Sat Jun 02 12:32:17.304644 2018] [ssl:warn] [pid 23892:tid 34397577216] AH01873: Init: Session Cache is n$
[Sat Jun 02 12:32:17.308832 2018] [mpm_event:notice] [pid 23892:tid 34397577216] AH00489: Apache/2.4.33 (F$
[Sat Jun 02 12:32:17.308942 2018] [core:notice] [pid 23892:tid 34397577216] AH00094: Command line: '/usr/l$
This is going to prevent you from obtaining a Let's Encrypt cert unless you use DNS validation--that process must have port 80 open to function.Ran port scan from http://www.whatsmyip.org/port-scanner/server/ with only port 443 open
What happens when you try in each case, and are you trying to connect using HTTPS?
- Cannot browse to jail from local IP address inside my network
- Cannot browse to jail from hostname inside my network
- Cannot browse to jail from hostname outside my network
Unfortunately, that isn't unusual for residential ISPs. It will prevent you from getting a Let's Encrypt cert using HTTP validation--you'd need to use DNS validation instead, which means you need to use a compatible DNS host.After some digging around, it appears that my ISP is blocking port 80 now.
Again, what happens when you try?cannot seem to connect any other way.
The installation log isn't saved to disk anywhere, but you should be able to scroll back in your SSH client to see whatever you need.Is there a way to read the log of the installation?
Depends on how you got the cert in the first place, but the simple answer is that you do the same thing the script did to get the test cert, but without the --test flag. If you used HTTP validation, that would be:How do I change to a real certificate if the test certificate succeeded?
/root/.acme.sh/acme.sh --issue --home "/root/.acme.sh" -d ${HOST_NAME} -w /usr/local/www/apache24/data -k 4096 --fullchain-file /usr/local/etc/pki/tls/certs/fullchain.pem --key-file /usr/local/etc/pki/tls/private/privkey.pem --reloadcmd "service apache24 reload"
