Resource icon
Scripted installation of Nextcloud 28 in iocage jail 2018-03-23
Semmel
.... Nas.tk {
root /usr/local/www/nextcloud
log /var/log/nextcloud_access.log
errors /var/log/nextcloud_errors.log
tls
ca https://acme-v02.api.letsencrypt.org/directory
dns cloudflare
fastcgi / 127.0.0.1:9000 php {
env PATH /bin
env modHeadersAvailable true
env front_controller_active true
connect_timeout 60s
read_timeout 3600s
send_timeout 300s
header / {
Semmel
Hmm strange. Added the brackets. Caddy now running as pid 17838. Will continue tmw with this. Thank you so much for the good help. Happy to donate if I can
Semmel
I did an fresh install and got the following error during install:
"Destination: /../../../usr/ports does not exist or is not a directory."
in the config file i set the ports folder somewhere else..
later it did install all the ports in usr/ports
But it keeps saying: Ports collection not supported, please update build
Semmel
i am now getting, ERR_TOO_MANY_REDIRECTS
and i am not able to login for a local machine
EDIT: So after changing the key from API to Origin in the rc.conf file i got it to work! all seems to work fine now!
mendocino
Hi, i installed nextcloud a couple of months ago using this script and it was great, but a few days ago i received a letter from Let's Encrypt warning that the certificate is expiring. I see at the moment there is an updated script and the first question is whether it is possible to upgrade jail using an updated script without losing data. Another question is if it is not possible to change the use of jail tnaujinti sriptu how to solve the problem with https certificate.
I used a domain from freenom.com
The router has ports 80 and 443 open. I'm attaching a caddy log file where my domain name is changed to mydomain.ml and my external IP is changed to 84.240. **. ***
  • caddy_1.txt
Disregard... it just takes a REALLY long time (about 90 minutes)
Good afternoon gents...
I seem to be getting a hangup on (or after) Executing Poststart OK
Anyone else encounter this and know a workaround?
(FYI: running on FreeNAS 11.3-RC1 and changed line 151 to reflect the correct package... everything seems ok until that point (i did try canceling, deleting and starting over))
OK, got this beast up an running...
Cant seem to get it to sign one of my site's certificates, and throws unsecure errors on the other... but not worried about that yet...
Trying to clean up NextCloud security flags (for some reason, file names is one but is fixed by running an occ command to convert the (i think long file names)...
Anyway, down to this weird one and i, for the life of me, can not clean it up... Ive looked everywhere for where Caddy might have it set, Ive looked into PHP, nginx, apache... grr...
Anyway, error in nextcloud security checks is:
The "X-Frame-Options" HTTP header is not set to "SAMEORIGIN". This is a potential security or privacy risk, as it is recommended to adjust this setting accordingly.
any help is appreciated...
This is addressed here:
I'll need to update the Caddyfile in the repo to really fix it, but you can modify yours by adding the line indicated in that issue.
OH!!! SH*T... all ive needed to do is ADD the line? Ive spent like 3 hours LOOKING for the line in other config files :)
You may also want to have occ chmod set to executable (something i noticed ive had to do manually each time ive installed via script)
And, im not 100% sure of the app they use, but have ou ever considered adding in the same post-setup app that the raspberry pi nextcloud build uses within Nextcloud? Ill see if i can get mine up again to see what app it is, but its really cool and will let you run all the security signing stuff post-install... NextCloudPlus (formerly NextCloudPi) uses a web GUI to do some of (a lot of) the back end stuff... Using a web pluging (or something) called ncp-web. I'll look into if its possible to add that kind of thing to a standalone NextCloud... but it's probably out of my talent range... It would make it relatively easy to streamline your script and allow some of the configuring to happen post-install...
is it possible to set up with no SSL security at installation and then set up a secure connection after install?
And, if so... any chance you know the best way to go about doing so? (I can not, for the life of me, get my company's website to be registered correctly... im happy to send you a private link if you want to look at it, but its not super important...) and No-IP for some reason, gets security flags when visiting it even though it seems to register perfectly fine... (Sorry, I just learned to read instructions correctly... Running the cleanup script clears up the flags for the No-IP forward)
Yes, but it'd be manual work. Briefly, you'd set it up with NO_CERT=1, and then when you want to use SSL instead, change the Caddyfile accordingly (you can use one of the templates with the script as a model). If you're fine using Let's Encrypt, use one of those Caddyfile versions--that's the most-common way to use Caddy. Otherwise, you can use the self-signed cert version along with any cert you've obtained elsewhere.
The recommended way to run occ is with php occ ..., so there's no reason that occ itself needs to be executable.
Ivolve
Hey Dan, Thanks for the script it worked perfectly!
Just a quick (newbie) question. I'm trying to install the preview generator. I have installed the app and have managed to SSH into the jail. I found on page 56 that I probably need to run this command:
su -m www -c 'php /usr/local/www/nextcloud/occ preview:pre-generate-all -vvv'
When I do this I'm promted for a password. I'm guessing this would be the password for user www but I can't figure out what it is...
You shouldn't ever need to SSH into a jail--SSH to your FreeNAS box, then iocage console nextcloud. And apparently you aren't logging in as root, otherwise you wouldn't be prompted for a password (which the www user doesn't have)--and the latter is the real issue. So, you need to become root in the jail--either log in as root directly, or su to root once you're logged in (which will require root's password, which you'll need to set--better to do as I said initially, be root on FreeNAS, then enter the jail). You'll then be able to su to another user without needing that user's password.
Ivolve
Thanks, that worked. Could you also advise on how to plan a cron job to keep the previews up-to-date? Can this be done through the gui?
You could do it through the GUI (the command would be iocage exec nextcloud su -m www . . .), but I'd lean toward doing it as a cron job in the jail itself. Enter the jail, do export EDITOR=nano, and then crontab -u www -e, which will bring up the www user's crontab file. Because it's already the www user, the "su -m www" part isn't needed, so the command would just be php /usr/local/www/nextcloud/occ preview:pre-generate-all -vvv (unless the command for repeat use is different).
Morrian
Sooo i followed every step of the guide BUT while i try to install/use the script i get the same error all the time:
root@freenas[~/freenas-iocage-nextcloud]# ./nextclou
ls: /mnt/tank/db: No such file or directory
nextcloud successfully created!
Testing SRV response to FreeBSD
pkg.freebsd.org's SRV record could not be verified.
Testing DNSSEC response to FreeBSD
pkg.freebsd.org could not be reached via DNSSEC.
Testing DNS response to FreeBSD
pkg.freebsd.org could not be reached via DNS, check
Failed to create jail
What did i wrong? What am i missing?
edit: it creates the jail
When i try it again it says, that the jail already exists............... freenas. what a joy
edit2:
i think somehow the jail kannt connect to the internet or something like taht. dont understand it and donmt really know how to check/fix it
edit3: Opend all ports in my fritzbox. still same error
Yes, that's what's going on. What version of FreeNAS are you using? And what's in your nextcloud-config file (masking any DNS credentials)?
