- Dec 31, 2021
Anything I need to be worried about for now?On the reverse proxy warning, see:
"The reverse proxy header configuration is incorrect, or you are accessing Nextcloud from a trusted proxy"
<details><summary>Support intro</summary>Sorry to hear you’re facing problems help.nextcloud.com is for home/non-enterprise users. If you’re running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly. In order to help...help.nextcloud.com
As I understand, the reverse proxy I only so you can run multiple instances behind your reverse proxy using the same DNS name on each with different paths like
cloud.domain.com/nextcloud
cloud.domain.com/owncloud
Etc
