Resource icon
Scripted installation of Nextcloud 19 in iocage jail 2018-03-23
InGenetic
Member
Since you only have one disk right now, you apparently don't care about redundancy. In that case, you should be able to replace the old disk through the GUI. Plug in the new one, go to Storage -> Pools, click on the gear, click Status, select the three vertical dots to the right of your current disk, select Replace, pick the new disk. Wait for the server to do its thing, then you can remove the old disk.
But consider adding a second 4 TB disk to create a mirror--which you'll unfortunately need to do at the CLI.
Hi mr.danb35,
sorry for bringing up , and old post .
as ur advice, i will replace HDD 500GB my freenas which nextcloud inside to 2 HDD 4TB ( mirror )
can u give me some information about procedure and how to replace my hdd 500GB to 2 hdd 4TB ( mirror ) on my freenas system ?
Thank you
Regards,
Patrick M. Hausen
Dedicated Sage
Add both 4 TB disks to your system if mounting space and number of SATA ports allow.
Attach both new disks to the existing vdev (don't create a new vdev!) to build a three-way mirror.
Detach old disk from three-way mirror.
Resize partitions to make use of the entire space if necessary.
The last step probably requires use of the CLI, the rest should be available in the UI.
InGenetic
Member
hi Patrick ,
may i ask for the command for that steps ? is it not via GUI freenas ?
because i'm new in linux and also freebsd command,
all i've done mostly using GUI interface.
still dunno what must i starting to do .
Thank you .
Regards,
Patrick M. Hausen
Dedicated Sage
Have you done all the other steps via the UI, already? The last step may not be necessary.
Patrick M. Hausen
Dedicated Sage
Please mount and connect the two additional disks. And as I wrote all but the last step - which might not even be necessary - can be done in the UI.
Once your disks are connected go to Storage --> Pools --> your pool, little gear icon --> Status. Then click on the menu to the right for your single disk and select Extend like in the screenshot. Pick one of your new disks and apply. Repeat for the second new disk.
Once the resilver is done, please report back.
Wizened Sage
InGenetic
Member
Hi Mr.Patrick and mr. danb35 ,
really thanks for your advice ,
i' ll report later , because there's a small problem here, one of my new hdd 4TB was defect, i have to RMA the HDD .
Regards,
Wizened Sage
You could still add the other one as a mirror, which would give you some redundancy. Of course, that's assuming you've already successfully burned in and tested that one.
G8One2
Member
Quick question for @danb35
NextCloud is showing an update in the web UI. Whats the best way to update? Last time I updated, I used the web interface, and wound up doing a reinstall and getting it stuck in maintenece mode. I was able to get it back up and updated, but I feel I went about updating the server the wrong way. Is there a correct process for updating?
Wizened Sage
AFAIK, you should be able to do it through the GUI, but it's always good to take a snapshot first.
Wizened Sage
I have done several, including the one from today (20.0.5 to 20.0.6) with success.
nikinp
Member
Dear danb35/(& other freenasers)
You referred me to this script from another post - but I pretty inexperienced in all this. I wanted to check I am on track to run the script.
I am running FreeNAS-11.3-U2.1.
I've followed the guide in detail, here's the sum total of what I have done:
Running
Want to use Lets Encrypt. I note the references to Caddy. I do not know if there are pre-requisite steps for Caddy, as I have no knowledge / use of this so far.
0. Pre-requisites as per guide.
1. Bought .com domain
2. Registered free plan with Cloudflare and used in txt file below
3. Added site to Cloudflare
4. Updated DNS Nameservers to Cloudflare ones
5. Created API token on Cloudflare and used in txt file below
6. Created 1 dataset with 4 sub-datasets are per instructions
7. Downloaded repository and created text file (nextcloud-config.txt) as per below. Pool_Path is to the dataset I created. Hope that's correct?
JAIL_IP="192.168.0.X"
DEFAULT_GW_IP="192.168.0.X"
POOL_PATH="/mnt/Nikin_ZFS/nextcloud"
TIME_ZONE="Europe/London"
HOST_NAME="Xl.com"
DNS_CERT=1
DNS_PLUGIN="cloudflare"
DNS_TOKEN="XXXXX"
CERT_EMAIL="X@X.co.uk"
I noted the comment in the guide. "HOST_NAME" needs to resolve to your jail from inside your network.... I dont know what this means or if I need to do this before running the script (which I have not done yet). Also the Nameservers take 24hrs to update, so I was waiting for that to happen too.
Do I need to do anything else before running the magical script?
Thanks in advance
Wizened Sage
Generally looks good, but a few points:
The script installs Caddy, so the noted prerequisites should cover everything it needs as well.
The file name should be just nextcloud-config, not nextcloud-config.txt.
POOL_PATH should be, as the README says, the path for your pool. Unless you set other locations (which you haven't in the example you posted), all the relevant files will be stored in $POOL_PATH/nextcloud/{db|files|config|themes}.
Apologies if this sounds blunt, but what part of it confuses you?
nikinp
Member
Not being blunt. Rather helpful that way, I think!
Thanks for the catch on the filename.
Re POOL_PATH. My pool is Nikin_ZFS within this I have created the 1+4 datasets. So perhaps it should read POOL_PATH=""/mnt/Nikin_ZFS"
I dont know what I have have to do to ensure "HOST_NAME" resolves to your jail from inside the network. ?
Wizened Sage
Correct.
Whatever device is providing DNS service for your LAN (likely your router) is where this really should be configured, assuming it has the capability to do it. Can't really help much more unless you're using pfSense or perhaps OPNsense.
nikinp
Member
Correct.
I ran the script. Final output is
Installation complete!
Using your web browser, go to https://X.com to log in
Default user is admin, password is X
Database Information
Database user = nextcloud
Database password = X
The MariaDB root password is X
All passwords are saved in /root/nextcloud_db_password.txt
You have obtained your Let's Encrypt certificate using the staging server.
This certificate will not be trusted by your browser and will cause SSL errors
when you connect. Once you've verified that everything else is working
correctly, you should issue a trusted certificate. To do this, run:
iocage exec nextcloud /root/remove-staging.sh
Script done, output file is nextcloud.log
root@freenas:/download/freenas-iocage-nextcloud #
However, when I go to http://X.com it just takes me to a easydns marketing page. Are there some configurations on the domain/cloudflare to point it to my nas?
Wizened Sage
That depends. Do you want to access the Nextcloud installation from outside your LAN? If not, then no, there's really nothing you need to do on that end (if yes, then you'd need to point the domain name to your IP address and forward ports to the Nextcloud jail). What you do need to do is what we've been discussing--figure out, on your network, with your devices, how to have X.com resolve to the IP address of your jail.
