Script to report zpool drive information. v1.0.5 "zpool-drive-info.py"
rluiten
Friend was getting annoyed with figuring out physical drive information in all his zpools so wrote this.
It dumps all the devices in a zpool looking up the device id, device info and serial number.
Its been tested on FreeNAS 8.3 and 9.3 so far.
To use it copy the attached file and rename it to remove the ".txt" extension.
Login as root on your FreeNas box and execute it with python.
For my zpool is called tank.
"python zpool-drive-info.py tank"
Have another friend using it capture state of his build, in case he cant get the same information back later if something is in an error state.
I have attached v1.0.5
I am a developer though havn't used python much so maybe its a bit naive.
I am also not an expert on FreeNAS or ZFS but I believe I havn't made serious errors.
This script does not write any data to disk or change any confguration state.
It only executes the following commands to collect information and present it.
# "zpool status"
# "camcontrol devlist"
# "glabel status"
# "smartctl -i /dev/<device>" - this is run for each device to lookup serial
WARNING - Any script you find on the internet might be doing bad things so in general you should not just grab it and run it. Either you should understand it or someone you trust understands it before running it.
Example output. I hid the serial numbers in the example.
[root@tonk] /mnt/tank/b1# python zpool-drive-info.py tank
      pool:  tank
      vdev:    raidz1-0 (1)
    device:        ada0
driveinfo:        <Hitachi HDS5C3030ALA630 MEAOA5C0>
    serial:        [Serial Hidden]
    device:        ada1
    device:        ada2
    device:        ada3
    device:        ada4
    device:        ada5
  • zpool-drive-info.py.txt
DrKK
FreeNAS Generalissimo
I ran your script and it turned my box into a gayporn streaming service!!!!!
Oh no wait, my bad, I was ssh'd into Cyberjock's box. The script seems fine.
KevinM
Not sure if the OP's friend cares about getting the script running on 9.10, but all 6 drives in my raidz2 vdev have the same driveinfo output:
[root@freenas] ~# python zpool-drive-info.py pool
      pool:  pool
      vdev:    raidz2-0 (1)
    device:        da0
 driveinfo:        Weird "da0" not found in device list
    serial:        13K82P0AS
DrKK
      pool:  pool
      vdev:    raidz2-0 (1)
    device:        da0
    serial:        13K82P0AS
That's unlikely to be a 9.10 vs 9.3 problem. Can we see the output of "camcontrol devlist", please, on your box?
KevinM
[root@freenas] ~# camcontrol devlist
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 2 lun 0 (da0,pass0)
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 3 lun 0 (da1,pass1)
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 4 lun 0 (da2,pass2)
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 5 lun 0 (da3,pass3)
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 10 lun 0 (da4,pass4)
<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 11 lun 0 (da5,pass5)
<SATA SSD S9FM01.6>                at scbus1 target 0 lun 0 (ada0,pass6)
KevinM
The formatting inside the ()'s is different on my 8.3.2 boxes.
[root@freenas01] ~# camcontrol devlist
<LSI SAS2X28 0e0b>                 at scbus0 target 8 lun 0 (ses0,pass0)
<LSI SAS2X36 0e0b>                 at scbus0 target 9 lun 0 (ses1,pass1)
<SEAGATE ST33000650SS 0004>        at scbus0 target 10 lun 0 (pass2,da0)
<SEAGATE ST33000650SS 0004>        at scbus0 target 11 lun 0 (pass3,da1)
<SEAGATE ST33000650SS 0004>        at scbus0 target 12 lun 0 (pass4,da2)
<SEAGATE ST33000650SS 0004>        at scbus0 target 13 lun 0 (pass5,da3)
<SEAGATE ST33000650SS 0004>        at scbus0 target 14 lun 0 (pass6,da4)
<SEAGATE ST33000650SS 0004>        at scbus0 target 15 lun 0 (pass7,da5)
<SEAGATE ST33000650SS 0004>        at scbus0 target 16 lun 0 (pass8,da6)
<SEAGATE ST33000650SS 0004>        at scbus0 target 17 lun 0 (pass9,da7)
<snip>
< Patriot Memory PMAP>             at scbus8 target 0 lun 0 (pass42,da36)
DrKK
I'll take a look at the script myself--it's probably an easy fix.
But I'd love to ask: Why in Muhammad, Buddha, and Jesus' name are you running 8.3.2 boxes?
DrKK
take the three lines that are "commented" in here with the #, and take out the # temporarily. Then show me the output when you run it please.
# print camcontrol
camcontrolStucture = {}
for line in camcontrol.splitlines():
  # print "a", "\"" + line + "\""
  match = re.search(r'^\s*(.*)\s*\sat\s.*,([^)]+)\)$', line)
  if match:
  camcontrolStucture[match.group(2)] = match.group(1).strip()
# print "camcontrolStucture", camcontrolStucture
KevinM
I know, it's nasty. They're Supermicro e1r36n boxes at work. For the most part one serves up the storage and the other is a replication target. The primary hosts a bunch of nfs storage for vsphere, 20+ tb storage for veeam backups, misc direct-attach nfs and iscsi, etc. Taking them off line is a major event. I did it once when a usb key failed, but otherwise I just let them chug along.
I'm not going to even try to update them. I went through that with my home freenas box and I don't consider the major version upgrade process reliable enough to use in production.
I ordered a couple of new e1cr36l boxes. When I get them online I'm going to migrate the data off the existing boxes, then i'm going to wipe them and set them up as replication targets.
KevinM
# print camcontrol
  if match:
[root@freenas] ~# python ./zpool-drive-info.py pool
a "<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 2 lun 0 (da0,pass0)"
a "<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 3 lun 0 (da1,pass1)"
a "<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 4 lun 0 (da2,pass2)"
a "<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 5 lun 0 (da3,pass3)"
a "<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 10 lun 0 (da4,pass4)"
a "<ATA TOSHIBA DT01ACA3 ABB0>        at scbus0 target 11 lun 0 (da5,pass5)"
a "<SATA SSD S9FM01.6>                at scbus1 target 0 lun 0 (ada0,pass6)"
camcontrolStucture {'pass4': '<ATA TOSHIBA DT01ACA3 ABB0>', 'pass5': '<ATA TOSHIBA DT01ACA3 ABB0>', 'pass6': '<SATA SSD S9FM01.6>', 'pass0': '<ATA TOSHIBA DT01ACA3 ABB0>', 'pass1': '<ATA TOSHIBA DT01ACA3 ABB0>', 'pass2': '<ATA TOSHIBA DT01ACA3 ABB0>', 'pass3': '<ATA TOSHIBA DT01ACA3 ABB0>'}
      pool:  pool
      vdev:    raidz2-0 (1)
    device:        da4
 driveinfo:        Weird "da4" not found in device list
    serial:        Y41TRV7GS
    device:        da5
 driveinfo:        Weird "da5" not found in device list
    serial:        168T3NGKS
    device:        da3
 driveinfo:        Weird "da3" not found in device list
    serial:        13F7AESAS
    device:        da2
 driveinfo:        Weird "da2" not found in device list
    serial:        13K84SXGS
    device:        da1
 driveinfo:        Weird "da1" not found in device list
    serial:        13K8LLNGS
    device:        da0
    serial:        13K82P0AS
DrKK
well I think we see what the problem is. It's pulling down the second tag instead of the first. The script should be written so that it determines which coordinate has the (a)da tag in it, not just assume it's in the second place.
If I get a chance later I'll fix it.
rluiten
Wow, greatwork DrKK.
I had made assumptions on data format.
I have update and attached the script so it should not care about the order of those last two fields from "camcontrol devlist".
KevinM
Works on 9.10!
      pool:  pool
      vdev:    raidz2-0 (1)
    device:        da4
 driveinfo:        <ATA TOSHIBA DT01ACA3 ABB0>
    serial:        Y41TRV7GS
DrKK
MrToddsFriends
Documentation Browser
Nice utility, unfortunately v1.0.6 (and maybe the versions before) doesn't display the desired information for pools made out of a single vdev that consists of a single disk.
In such a case there is no line stating 'mirror-0', 'raidz2' or whatsoever.
[root@blunzn] ~# zpool status volrep
  pool: volrep
state: ONLINE
  scan: scrub repaired 0 in 1h57m with 0 errors on Sat Apr 16 00:57:39 2016
        NAME                                          STATE     READ WRITE CKSUM
        volrep                                        ONLINE       0     0     0
          gptid/61f19d27-e65e-11e4-afbd-0cc47a317e3c  ONLINE       0     0     0
errors: No known data errors
This leads to no match for a dev level 2 in your code with the following output for a single disk:
[root@blunzn] ~# python ./zpool-drive-info_orig.py volrep
      pool:  volrep
      vdev:    gptid/61f19d27-e65e-11e4-afbd-0cc47a317e3c (1)
I created a small hack to your code to circumvent this situation, but be warned: I'm an absolute beginner in python. And: My patch results in handling single disks as dev level 1 and dev level 2 at the same time (I don't know if this could harm in combination with other disk configurations than mine).
The patch:
[root@blunzn] ~# diff zpool-drive-info_orig.py zpool-drive-info.py
89a90
>  matchgptid = -1 # single disk marker
91a93,94
>  # single disk is handled as dev level 1 and dev level 2 at the same time
>  matchgptid = newDev1.find("gptid")
96c99
<  if match and match.start(1) == 4:  # found dev level 2
>  if (match and match.start(1) == 4) or (matchgptid >= 0):  # found dev level 2
With this patch the output for the single disk (and single vdev) pool is:
[root@blunzn] ~# python ./zpool-drive-info.py volrep
      pool:  volrep
    device:        ada2
driveinfo:        <WDC WD20EFRX-68AX9N0 80.00A80>
    serial:        WD-WMC300241919
All testing done with FreeNAS 9.10, 2-way mirror vdevs (one vdev per pool) and this single disk pool. Maybe this helps for further development.
rluiten
That seems a very reasonable way to resolve it, thanks for the feedback.
I did change your variable name.
Updated script v1.0.7
MrToddsFriends
Assuming you don't have such a degenerated vdev at hand: Output of v1.0.7 is identical to that of my patched v1.0.6 with my disk configuration.
rluiten
You are right I do not have access to any setup like that. I can substitute the return result of the run commands to get specific scenarios for for testing, (you can see import test commented out at top and some other test lines commented out) to check it "should" work, its nice to have confirmation though, Thanks.
I should look at using a test runner, but I don't do much python and just couldn't be bothered.
