Greetings fellow FreeNASonites!
I'm a newb to FreeNAS, and am having some issues with VLAN's. I recently installed a Intel Pro 1000 MT dual nic Gig PCI card, and it works great...after i reset the network config at the box via keyboard (console i believe is what the screen / environment is called). My question is: is there a scrip to "restart network" after it boots up?
To be exact: i start my FreeNAS, and the console page shows two "0.0" IPs, which are not the static IPs set by a seperate router / firewall. However, when on the console page i select network config (1) -> Reset vlanxx, it shows the correct static ips. Since this FreeNAS box does not have a keyboard and mouse attached to it (nor do i want that), id like to (if possible) create or use a script that will restart my network configs on the freenas after bootup, so the freenas will essentially do a windows version of dhcp /release and /renew...if that spanglish makes any sense :)
Cheers!
-\ Wakesk8r /-
Cheers!
-\ Wakesk8r /-
