SCALE virtualized on ESXi - which network interface?
Patrick M. Hausen
Hi all,
what's the recommended virtualized network interface for such an environment? (disk controller passed through, of course)
VMXNET3, E1000, something else?
Thanks,
Patrick
As I understand it, the drivers are built in (also on CORE), so I would use that every time.
That driver is going to be the one with the highest number of testing hours.
Patrick M. Hausen
Well, specifically our resident Grinch has been quite vocal about the deficiencies of VMXNET3. So i was curious if there's a difference between FreeBSD and Debian support and if that matters or if I should just stick with E1000.
I don't think you'll get 10G on E1000... maybe the argument is that you don't even if it says it does with VMXNET?
Patrick M. Hausen
The reported speed that the OS displays at initialization time is irrelevant for virtualized interfaces. E1000 can go well over 1G. I am more concerned with stability. Don't know if any of them can saturate 10G.
Mlovelace
VMXNET3 supports additional off-loading, which you probably won't be leveraging, so it's actually irrelevant (or academic maybe a better word) which virtual interface you choose, as the open-vm-tools drivers are quite mature and support both equally well.
