Patrick_3000
- Apr 28, 2021
I have an interface, enp16s0f1, which is the only physical interface in a bridge, br0, that is used to access the SCALE web UI. This interface, enp16s0f1, is always online unless something goes wrong,
I just updated to SCALE 23.10.1, and even though enp16s0f1 is online (which it clearly is because I can access the web UI), it shows as offline under the network tab. Before the upgrade, it showed online in the network tab. Now, after the upgrade, the bridge, br0, is the only interface that shows online under the network tab.
Does anyone know anything about this or whether it's expected behavior? It doesn't make sense to me that enp16s0f1 would show in SCALE as offline if it's actively sending and receiving packets, which it is. More likely, it's a bug in 23.10.1, but I wanted to see if anyone has any information.
In case it's relevant, enp16s0f1 is an SFP+ interface on an Intel x710-DA2 network card with a multimode transceiver, connected to a switch.
