The bottom line is that you want to use a SAS HBA instead. Please also have a look at "SAS and SATA" and "Don't use RAID" in the recommended readings in my signature. The forum has a ton of threads on this topic as well.
In the last year or two, we've had a resurgence of users asking about SATA Port Multipliers and cheap SATA controllers. Please, do NOT use port multipliers, and use cheap SATA controllers only after extensive research. SATA controllers and SATA...
www.truenas.com
But having said that, it looks like the construction of the card is six independent ASM1064 controllers and some sort of bridge. If they're legit non-knockoff ASM1064, this might actually work just fine. On the other hand, there's a nontrivial risk that there could be a driver limit to the number of SATA AHCI are supported, so there could be risks here especially if you tried to add two or three of these to a system.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
