Hey All,
My NAS is pretty old at this point, I'm running a Supermicro X10SLL-F Xeon E3 LGA1150 DDR3 ECC C222 6SATA 3PCIE IPMI 2GBE mATX Motherboard. I have 6x4TB disks in RAIDZ2.
I need to replace a couple disks so since my motherboard is capped for SATA ports I was thinking of getting an HBA to support more disks so I can put the OS on a SATA disk instead of a flash drive, and a new RAIDZ1 array for crap I don't really care about but would be annoying at best if I had to regather it.
What kind of HBA would be supported and work with this motherboard? I'm not sure what the recommended hardware would be.
I'm running the latest TrueNAS SCALE right now.
Thank you!
Thank you!
