just trying to install some new HW and I used a new LSI HBA: https://www.amazon.de/-/en/LSI-2008-8E-LSI9200-8E/dp/B01M9GRAUM
I can see it in the console (using sas2flash -list):
LSI Corporation SAS2 Flash Utility
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved
Adapter Selected is a LSI SAS: SAS2008(B2)
Controller Number : 0
Controller : SAS2008(B2)
PCI Address : 00:06:00:00
SAS Address : 56c92bf-0-0003-90f0
NVDATA Version (Default) : 14.01.00.08
NVDATA Version (Persistent) : 14.01.00.08
Firmware Product ID : 0x2213 (IT)
Firmware Version : 20.00.06.00
NVDATA Vendor : LSI
NVDATA Product ID : SAS9211-8i
BIOS Version : 07.39.00.00
UEFI BSD Version : 07.27.01.01
FCODE Version : N/A
Board Name : SAS9211-8i
Board Assembly : SAS2008IT
Board Tracer Number : SAS2008IT90F0
Finished Processing Commands Successfully.
Exiting SAS2Flash.
Above output is from a different PC with Windows since this PC won't remove the card after some minutes. E.g. everything except addresses are the same on different PCs :)
I searched the forum and saw that some people had problems with BIOS Version : 07.39.02.00 and their HP systems. Since I also have a HP system:
I already downgraded the bios from 07.39.02.00 to 07.39.00.00
However truenas / the HP PC will still remove the card after some time and I can't access my HDDs.
To test it I removed everything from the PC (e.g. I rmeoved all cables and HDDs for the HBA) and only the bare minimum is still connected: one nvme disk for trueas and the HBA card itself.
Again I can see the card in the console for around 5 minutes then cards gets removed:
Sorry for the picture:
NVDATA Vendor : LSI
FCODE Version : N/A
Exiting SAS2Flash.
