samba4.Samba4Alert
tfran1990
freenas /alert.py: [system.alert:393] Alert module '<samba4.Samba4Alert object at 0x814cc9b70>' failed: Call timeout
the log doesnt tell much.
what does it mean, is it ok?
my system light at the top right is showing green?
You might want to file a bug report. Post the issue number here, please.
mvcad
I am having the same issue. Did you find a solution?
anodos
Sambassador
Okay. That looks like a middleware timeout. I've seen a couple in my logs. There are more efficient and less problematic ways of doing the logical tests in that alert. I'll try to get a PR in tomorrow related to it if I have time. Please update this thread if the error becomes a regular occurrence.
mvcad
Do you have AD monitoring enabled?
I don't know what that is to be honest. unless it is enabled by default I would say no.
mvcad
mvcad
Well, I tried the solution posted of the bug above mentioned, although zfs_space, zfsacl and streams_xattr modules were already enabled on all my SMB shares, hence the issue still persists.
mvcad
These are my error messages
Jun  8 20:10:46 freenas dhclient: New Subnet Mask (em0): 255.255.255.0
Jun  8 20:10:46 freenas dhclient: New Broadcast Address (em0): 192.168.1.255
Jun  8 20:10:46 freenas dhclient: New Routers (em0): 192.168.1.1
Jun  8 12:10:46 freenas python3.6: dnssd_clientstub DNSServiceProcessResult call
ed with invalid DNSServiceRef 0x81f41a480 FFFFFFFF DDDDDDDD
Jun  8 20:12:47 freenas /alert.py: [system.alert:393] Alert module '<samba4.Samb
a4Alert object at 0x814ccbd30>' failed: Failed connection handshake
Jun  8 20:14:25 freenas uwsgi: [plugins.utils:88] Couldn't retrieve https://192.
168.1.66/plugins/plexmediaserver/1/_s/status: The read operation timed out
Jun  8 20:14:38 freenas uwsgi: [plugins.utils:88] Couldn't retrieve https://192.
168.1.66/plugins/syncthing/2/_s/status: The read operation timed out
Jun  8 20:14:52 freenas uwsgi: [plugins.utils:88] Couldn't retrieve https://192.
168.1.66/plugins/nextcloud/3/_s/status: The read operation timed out
Jun  8 20:19:10 freenas /alert.py: [system.alert:393] Alert module '<samba4.Samb
Jun  8 20:25:45 freenas /alert.py: [system.alert:393] Alert module '<samba4.Samb
Jun  8 20:31:05 freenas kernel: arp: 192.168.1.66 moved from 02:07:50:00:06:0a t
o 70:85:c2:44:1a:9d on epair1b
Jun  8 20:32:17 freenas /alert.py: [system.alert:393] Alert module '<samba4.Samb
Jun  8 20:35:22 freenas /alert.py: [system.alert:393] Alert module '<samba4.Samb
anodos
Sambassador
Can you PM me a debug file? I'll take a look at it.
mvcad
I am generating the debug file right now but it has been more than 30 min already. doe it take that long? anyway, if it ever finishes I'll send it to you. thanks.
Also, the monitor attached to the FreeNAS box show no signal. Is this normal while writing the debug file?
mvcad
Debug file sent
mvcad
Problem fixed by rolling back a windows 10 update on my PC. Thanks Microsoft, you made me waste 1 week and rebuild my NAS for nothing.
CH4Pz
Dont suppose u know which update? im having same issue on 11.1 u6 ??
mvcad
CH4Pz
anodos
Sambassador
Some instances I've seen of this bug seem to be related to io timeouts on the boot device. If your server isn't already configured this way, try moving your system dataset to your data pool, then rebooting the server.
CH4Pz
excuse my noobiness, but how would i do that? can it be done through ui?
CH4Pz
nvm, i found it, but it was already set to "Z2_datasaet"
