I have a problem that I cannot figure out, and I wanted to ask you guys. I built TruenasCore on a system with 4 x NVME and 8 x SSD drives and created a pool with each drive. I shared it out over Samba, and I have a 40GB network card in both the Truenas system and the Windows PC. My speeds while doing network tests to the pool over Samba share were 2,000 MB/s for both read and write, using the AJA system test and Blackmagic. Even copying files to and from the system was getting 2k MB/s non-stop. However, I decided to give Scale a test with the exact same setup and pool, and my speeds are only 900 MB/s for both read and write. Same system, just Scale instead of Core. The only thing I can see that's different is that Core uses Samba version 4.15.11, and Scale uses Samba version 4.17.2. Any help would be appreciated.
Thank you.
Thank you.
