SAMBA service not starting on FreeNAS 11
Garyw
I just upgraded my FreeNAS box to FreeNAS-11.0-U4 (54848d13b) and now I cannot start SMB. When I try in the GUI, it looks like it's starting but doesn't actually get anywhere.
Trying from the CLI generates the following error:
root@store05:~ # service samba_server start
Performing sanity check on Samba configuration: FAILED
ok, so running a testparm and I get:
root@store05:~ # testparm
Load smb config files from /usr/local/etc/smb4.conf
Processing section "[veeam]"
Loaded services file OK.
ERROR: The idmap range for the domain * (tdb) overlaps with the range of HOME (rid)!
Server role: ROLE_DOMAIN_MEMBER
Press enter to see a dump of your service definitions
Any pointers on what I need to fix? This was all working before the upgrade so I wonder if this upgrade is a bit more strict or something.
anodos
Sambassador
It looks like your idmap ranges are overlapping. You should edit them so that they don't do that. One set is configured under services -> SMB and covers your BUILTIN users / groups / other crap. The other is under Directory Services -> Active Directory (next to the "idmap dropdown), and controls the range set for your AD users and groups.
anodos
Sambassador
Pretty much. They shouldn't overlap, and I wouldn't have any of them go lower than 3000. You should also leave yourself enough room for all the users in your AD environment.
Garyw
Thanks . I just tried changing the IDMAP range on the SMB service and got this error
iqSDXTBqVFVCrnN
