SAMBA(cifs) ip filter
muzhik
Hey!
I have few shared folders which access restrict by ip, without auth.
But today every folders which have ip settings tell to users that have to insert login\password.
I did not change owner for folders or someting else
How to fix?
D
dlavigne
Guest
Build version of FreeNAS (from System -> Information)? Client versions?
anodos
Sambassador
Hey!
How to fix?
Post contents of /usr/local/etc/smb4.conf
Post output of "getfacl /mnt/path/to/share"
Proper authentication is a much better solution than IP filtering.
muzhik
Yes, it works fine. i woudlike restrict by ip for /24 networks, it's not good making a lot of login-pass
anodos
Sambassador
[The following assumes that this FreeNAS server is in production in an office / work environment.] If you have lots of users then it's a better idea to implement a directory server (or just take the time to set up the users). It's trivially easy to bypass "hosts allow" on a typical LAN. It just gives an illusion of security.
muzhik
I have two /24 subnets, it's easy and comfortable devide subnets, and allow only 1 subnet, i dont want make for all users in subnet. it not demand for purpose\work
