I have been running freenas and Axis cameras for ages. Everything was working fine on 11.1-U5 (and below), but since I installed 11.1-U6, I cannot connect my cameras to the network share.
I have the share setup so everyone can access the share (guest access). When using a windows machine, I can browse and access the share without any issues or delays.
I use the Axis Companion Software to setup the cameras and when I try to setup the share, I just get "Could not contact the recorder (share)". I deleted the share, and recreated it with a different share name and same results.
Like I said, before 11.1-U6 it was working fine and without any hassle. The samba logs don't show anything ...
I also checked the Axis FAQ's and SMB3 is supported (cameras have the newest firmware installed).
So I am not sure why its not working unless I am looking at all the wrong places. I could defiantly use some help here.
Thanks.
Eddi
PS: in case you are interested, cameras are the Axis P3346, firmware version 5.51.5.1
Thanks.
Eddi
