SABnzbd update?
dedeaux
Is there a way to update the SABnzbd plugin manually?
Or... When can we expect the plugin to be updated here for FreeNAS?
Thanks!
Joshua Parker Ruehlig
I wanted to update three FreeNAS plugin and freebsd port last week but I noticed sabnzbd v1.1.1 was never released on sourceforge where the Makefile pulls the source from.
if you want to help you can ask the sabnzbd dev on his forum/github why v1.1.1 isn't available on sourceforge. if github is now the official spot I can update the freebsd port
dedeaux
All I see on their website is a github reference for the source. Maybe they aren't using sourceforge anymore? No worries.
yeah noticed that from their website too. k I asked on their forum
Schuby
Came here for this, but it looks like you're making progress. Can't wait for the plugin update :)
I wish SABnzbd could be updated like Sonarr.
agreed, that would make things alot easier.
sorry this updae has been delayed; sabnzbd moved where their files are hosted and I have been too busy to update the port/plugin.
sumdood
Is there any way you could post how you update you jail/pbi? I am getting a lot of error and wanted to update sab.
I finally got the update done. It should be available tomorrow.
Tell me if anyone has any issues with it.
ovizii
update had a few hiccups here as sabnzbd didn't start after the update so I tried manually:
root@sabnzbd_1:/ # service sabnzbd start
Cannot 'start' sabnzbd. Set sabnzbd_enable to YES in /etc/rc.conf or use 'onestart' instead of 'start'.
did that and could start it.
All good.
I see that the plugin shows 1.1.1 but the port tree is still showing version 1.1.0_1. Still issues with the hosting?
i already found a solution and submitted it to the bug report. just no one is accepting my changes.
TheDubiousDubber
Updated and appears to be working after restarting plugin. Oddly there is no longer a version though. It does not list it as 1.1.1, instead it just says develop [unknown].
Nice catch, I think I had some caching issue when building the plugin. It should continue to work, but I'll see if I can rebuild it with the actual version 1.1.1
