Sabnzbd permissions problem
Vinh
drwxrwxr-x+  55 media  media       385 Apr 14 17:31 Anime
drwxrwxr-x+   6 media  media         7 Jan  3 15:43 Apps
drwxrwxr-x+  14 media  media        14 Jan 26 17:44 Books
drwxrwxr-x+   3 media  media         4 Jan  3 15:46 Misc
drwxrwxr-x+ 118 media  media       120 Apr 13 08:33 Movies
drwxrwxr-x+  84 media  media        85 Jan  3 15:47 Music
drwxrwxr-x+  67 media  media        67 Apr 17 10:57 TV
ls -l /path/to/files
then check if there are "+" at the end.
looks like all of the have the "+" at the end. How do i go about getting rid of them? Thanks again fro the quick response and help
Joshua Parker Ruehlig
idk, never dealt with it myself. though I have read of people using a command to get rid of them before
Vinh
To share with other people I was able to remove the ACL priv with the following command
to remove the '+' from the folder - setfacl -b /path to folder
to set privs as default - setfacl -d /path to folder (the will make it so any new files made in the fold will have same privs, i.e. no '+' a the end)
to do recursive for existing files in the folder - setfalc -b /path to folder/*
RoadHazard
Like many others, I get frequent 'cannot change permission' errors from SABnzbd, but apart from that, it seems to work okay. Nevertheless, I'd like to understand and fix the problem.
A look inside its jail shows some odd information. Both the user 'media' and the group 'media' have the UID/GID of 8675309 (yes, like the song). Shouldn't the UID be 816? And shouldn't the GID always be < 32767 anyway?
Is this a real problem, or am I barking up the wrong tree? And should I manually change the UID and/or the GID to more rational values?
