Sabnzbd 1.0 webgui refusing connection
fmdx
I was happy to see that Sabnzbd finally made it to 1.0 status, and tried updating the plugin. After updating, the webgui would throw "This webpage is not available ERR_CONNECTION_REFUSED".
I've tried with fresh plugin installs, and still the same results even after rebooting the box (which sometimes fixes any DHCP related issues).
There is nothing in footer console to indicate it's thrown an error.
Any ideas?
Joshua Parker Ruehlig
can you check the log in /var/db/sabnzbd. strange that even a fresh install isn't working because that definitely worked in my testing.
fmdx
In Sabnzbd.log:
2016-03-19 03:09:58,115::INFO::[SABnzbd:1246] --------------------------------
2016-03-19 03:09:58,115::INFO::[SABnzbd:1247] SABnzbd.py-1.0.0 (rev=a58bb385f57$
2016-03-19 03:09:58,115::INFO::[SABnzbd:1248] Full executable path = /usr/pbi/s$
2016-03-19 03:09:58,116::INFO::[SABnzbd:1260] Platform = posix
2016-03-19 03:09:58,116::INFO::[SABnzbd:1261] Python-version = 2.7.9 (default, $
[GCC 4.2.1 20070831 patched [FreeBSD]]
2016-03-19 03:09:58,116::INFO::[SABnzbd:1262] Arguments = /usr/pbi/sabnzbd-amd6$
2016-03-19 03:09:58,116::INFO::[SABnzbd:1307] Read INI file /var/db/sabnzbd/sab$
2016-03-19 03:09:58,117::INFO::[misc:434] download_dir directory: /var/db/sabnz$
2016-03-19 03:09:58,121::INFO::[__init__:965] Loading data for queue9.sab from $
2016-03-19 03:09:58,121::INFO::[__init__:968] /var/db/sabnzbd/admin/queue9.sab $
2016-03-19 03:09:58,121::INFO::[__init__:965] Loading data for queue8.sab from $
2016-03-19 03:09:58,122::INFO::[__init__:968] /var/db/sabnzbd/admin/queue8.sab $
2016-03-19 03:09:58,122::INFO::[__init__:965] Loading data for queue7.sab from $
2016-03-19 03:09:58,122::INFO::[__init__:968] /var/db/sabnzbd/admin/queue7.sab $
2016-03-19 03:09:58,183::INFO::[__init__:965] Loading data for rss_data.sab fro$
2016-03-19 03:09:58,183::INFO::[__init__:968] /var/db/sabnzbd/admin/rss_data.sa$
2016-03-19 03:09:58,184::INFO::[__init__:965] Loading data for totals10.sab fro$
2016-03-19 03:09:58,184::INFO::[__init__:968] /var/db/sabnzbd/admin/totals10.sa$
2016-03-19 03:09:58,115::INFO::[SABnzbd:1247] SABnzbd.py-1.0.0 (rev=a58bb385f57d0c5c8a92b7e3ea082d776363767e)
2016-03-19 03:09:58,115::INFO::[SABnzbd:1248] Full executable path = /usr/pbi/sabnzbd-amd64/bin/SABnzbd.py
2016-03-19 03:09:58,116::INFO::[SABnzbd:1261] Python-version = 2.7.9 (default, Mar 16 2016, 09:00:34)
2016-03-19 03:09:58,116::INFO::[SABnzbd:1262] Arguments = /usr/pbi/sabnzbd-amd64/bin/SABnzbd.py --daemon -f /$
2016-03-19 03:09:58,116::INFO::[SABnzbd:1307] Read INI file /var/db/sabnzbd/sabnzbd.ini
2016-03-19 03:09:58,117::INFO::[misc:434] download_dir directory: /var/db/sabnzbd/Downloads/incomplete does n$
2016-03-19 03:09:58,121::INFO::[__init__:965] Loading data for queue9.sab from /var/db/sabnzbd/admin/queue9.s$
2016-03-19 03:09:58,121::INFO::[__init__:968] /var/db/sabnzbd/admin/queue9.sab missing
2016-03-19 03:09:58,121::INFO::[__init__:965] Loading data for queue8.sab from /var/db/sabnzbd/admin/queue8.s$
2016-03-19 03:09:58,122::INFO::[__init__:968] /var/db/sabnzbd/admin/queue8.sab missing
2016-03-19 03:09:58,122::INFO::[__init__:965] Loading data for queue7.sab from /var/db/sabnzbd/admin/queue7.s$
2016-03-19 03:09:58,122::INFO::[__init__:968] /var/db/sabnzbd/admin/queue7.sab missing
2016-03-19 03:09:58,183::INFO::[__init__:965] Loading data for rss_data.sab from /var/db/sabnzbd/admin/rss_da$
2016-03-19 03:09:58,183::INFO::[__init__:968] /var/db/sabnzbd/admin/rss_data.sab missing
2016-03-19 03:09:58,184::INFO::[__init__:965] Loading data for totals10.sab from /var/db/sabnzbd/admin/totals$
2016-03-19 03:09:58,184::INFO::[__init__:968] /var/db/sabnzbd/admin/totals10.sab missing
2016-03-19 03:09:58,184::INFO::[__init__:965] Loading data for totals9.sab from /var/db/sabnzbd/admin/totals9$
2016-03-19 03:09:58,185::INFO::[__init__:968] /var/db/sabnzbd/admin/totals9.sab missing
2016-03-19 03:09:58,267::INFO::[postproc:89] Loading postproc queue
2016-03-19 03:09:58,268::INFO::[__init__:965] Loading data for postproc2.sab from /var/db/sabnzbd/admin/postp$
2016-03-19 03:09:58,268::INFO::[__init__:968] /var/db/sabnzbd/admin/postproc2.sab missing
2016-03-19 03:09:58,269::INFO::[__init__:965] Loading data for queue10.sab from /var/db/sabnzbd/admin/queue10$
2016-03-19 03:09:58,269::INFO::[__init__:968] /var/db/sabnzbd/admin/queue10.sab missing
2016-03-19 03:09:58,270::INFO::[__init__:965] Loading data for queue9.sab from /var/db/sabnzbd/admin/queue9.s$
2016-03-19 03:09:58,270::INFO::[__init__:968] /var/db/sabnzbd/admin/queue9.sab missing
2016-03-19 03:09:58,271::INFO::[__init__:965] Loading data for watched_data2.sab from /var/db/sabnzbd/admin/w$
2016-03-19 03:09:58,271::INFO::[__init__:968] /var/db/sabnzbd/admin/watched_data2.sab missing
2016-03-19 03:09:58,116::INFO::[SABnzbd:1262] Arguments = /usr/pbi/sabnzbd-amd64/bin/SABnzbd.py --daemon -f /var/db/sabnzbd/sabnzbd.ini --pidfile /var/run/sabnzbd/sabnzbd.pid
2016-03-19 03:09:58,117::INFO::[misc:434] download_dir directory: /var/db/sabnzbd/Downloads/incomplete does not exist, try to create it
2016-03-19 03:09:58,121::INFO::[__init__:965] Loading data for queue9.sab from /var/db/sabnzbd/admin/queue9.sab
2016-03-19 03:09:58,121::INFO::[__init__:965] Loading data for queue8.sab from /var/db/sabnzbd/admin/queue8.sab
2016-03-19 03:09:58,122::INFO::[__init__:965] Loading data for queue7.sab from /var/db/sabnzbd/admin/queue7.sab
2016-03-19 03:09:58,183::INFO::[__init__:965] Loading data for rss_data.sab from /var/db/sabnzbd/admin/rss_data.sab
2016-03-19 03:09:58,184::INFO::[__init__:965] Loading data for totals10.sab from /var/db/sabnzbd/admin/totals10.sab
2016-03-19 03:09:58,184::INFO::[__init__:965] Loading data for totals9.sab from /var/db/sabnzbd/admin/totals9.sab
2016-03-19 03:09:58,268::INFO::[__init__:965] Loading data for postproc2.sab from /var/db/sabnzbd/admin/postproc2.sab
2016-03-19 03:09:58,269::INFO::[__init__:965] Loading data for queue10.sab from /var/db/sabnzbd/admin/queue10.sab
2016-03-19 03:09:58,270::INFO::[__init__:965] Loading data for queue9.sab from /var/db/sabnzbd/admin/queue9.sab
2016-03-19 03:09:58,271::INFO::[__init__:965] Loading data for watched_data2.sab from /var/db/sabnzbd/admin/watched_data2.sab
2016-03-19 03:09:58,271::INFO::[__init__:965] Loading data for Rating.sab from /var/db/sabnzbd/admin/Rating.sab
2016-03-19 03:09:58,272::INFO::[__init__:968] /var/db/sabnzbd/admin/Rating.sab missing
2016-03-19 03:09:58,273::INFO::[scheduler:190] Setting schedule for midnight BPS reset
2016-03-19 03:09:58,273::INFO::[downloader:241] Resuming
2016-03-19 03:09:58,301::INFO::[__init__:349] All processes started
2016-03-19 03:09:58,301::INFO::[SABnzbd:358] Web dir is /usr/pbi/sabnzbd-amd64/share/sabnzbdplus/interfaces/Glitter
2016-03-19 03:09:58,302::INFO::[SABnzbd:358] Web dir is /usr/pbi/sabnzbd-amd64/share/sabnzbdplus/interfaces/Config
2016-03-19 03:09:58,366::INFO::[SABnzbd:486] _yenc module... found!
2016-03-19 03:09:58,367::INFO::[SABnzbd:494] par2 binary... found (/usr/local/bin/par2)
2016-03-19 03:09:58,368::INFO::[SABnzbd:499] par2-classic binary... found (/usr/local/bin/par2)
2016-03-19 03:09:58,368::INFO::[SABnzbd:502] UNRAR binary... found (/usr/local/bin/unrar)
2016-03-19 03:09:58,368::INFO::[SABnzbd:508] unzip binary... found (/usr/bin/unzip)
2016-03-19 03:09:58,369::INFO::[SABnzbd:514] 7za binary... found (/usr/local/bin/7za)
2016-03-19 03:09:58,369::INFO::[SABnzbd:521] nice binary... found (/usr/bin/nice)
2016-03-19 03:09:58,370::INFO::[SABnzbd:527] ionice binary... NOT found!
2016-03-19 03:09:58,370::INFO::[SABnzbd:530] pyOpenSSL... found (True)
2016-03-19 03:09:58,371::INFO::[SABnzbd:1370] SSL version OpenSSL 1.0.2d 9 Jul 2015
2016-03-19 03:09:58,371::INFO::[SABnzbd:1371] pyOpenSSL version 0.15.1
2016-03-19 03:09:58,372::INFO::[SABnzbd:1372] SSL potentially supported protocols ['SSLv2', 'SSLv23', 'SSLv3', 'TLSv1', 'TLSv1_1', 'TLSv1_2']
2016-03-19 03:09:58,373::INFO::[SABnzbd:1373] SSL actually supported protocols ['t12', 't11', 't1', 'v23', 'v3', 'v2']
2016-03-19 03:09:58,377::INFO::[SABnzbd:1519] Starting web-interface on 127.0.0.1:8080
2016-03-19 03:09:58,378::INFO::[_cplogging:216] [19/Mar/2016:03:09:58] ENGINE Bus STARTING
2016-03-19 03:09:58,385::INFO::[_cplogging:216] [19/Mar/2016:03:09:58] ENGINE Started monitor thread '_TimeoutMonitor'.
2016-03-19 03:09:58,488::INFO::[_cplogging:216] [19/Mar/2016:03:09:58] ENGINE Serving on http://127.0.0.1:8080
2016-03-19 03:09:58,489::INFO::[_cplogging:216] [19/Mar/2016:03:09:58] ENGINE Bus STARTED
2016-03-19 03:09:58,490::INFO::[zconfig:64] No Bonjour/ZeroConfig support installed
2016-03-19 03:09:58,909::INFO::[SABnzbd:1591] Starting SABnzbd.py-1.0.0
2016-03-19 03:09:58,911::INFO::[dirscanner:302] Dirscanner starting up
2016-03-19 03:09:58,912::INFO::[urlgrabber:69] URLGrabber starting up
In the Sabnzbd.error.log it's empty.
fmdx
In my defense I did post first ;)
(And I did search for previous posts too lol)
lol, no worries, I just wanted to consolidate the discussion.
Using this thread from now on to discuss this issue.
I noticed on my system, where for my plugin jails I always disable VIMAGE and assign a NIC, my igconfig shows an IP for the assigned NIC and no IP 127.0.0.1 for the loopback (lo0) NIC.
Maybe in the default configuration sabnzbd is only listening on 127.0.0.1. I'll try to figure out a clean way to have it listen on all IPs by default.
fmdx
Anything to help :D
Hopefully it's a quick fix, I'm trying to get this up and running nicely before I put it in storage for a move :S
this should fix things for you, I'll get this in a plugin update soon
service sabnzbd stop
sed -i '' -e 's/\(^command_args=.\)\(.*\)/\1-s 0.0.0.0 \2/' /usr/pbi/sabnzbd-amd64/etc/rc.d/sabnzbd
service sabnzbd start
fmdx
Huzzah, I see the wizard now after reboot. Thanks Josh, keep doing that awesome plugin work :D
diskdiddler
So it'll be safe to just update the plugin from within the FreeNAS plugin menu then?
it should be, but I haven't incorporated the fix in yet so I'd wait if possible
Ok, I fixed this in the sabnzbd plugin but didn't bump the version (to keep in line with the official port).
The md5 of the correct PBI is "737327c73d33892d7a0d6aa" and it should be available normally from the freenas repo tomorrow.
If you'd rather patch an existing v1.0.0 install please run the following commands in sabnzbd's jail
bmcclure937
Is this all clear to upgrade now or do you still recommend holding off and waiting?
I think it should work now
bmcclure937
I guess I will give it a whirl... and report back when the update is complete. I am shutting down SAB plugin right now and will update. Hope that the settings carry over OK.
bmcclure937
The update was successful. Thanks for the great work!
awesome, that was quick
diskdiddler
Mar 22 13:28:52 freenas manage.py: [middleware.exceptions:37] [MiddlewareError: Failed to update plugin]
