I have added a DataSet to the SAB plugin jail. updated permissions that should allow it to write to the directories. Everything looks correct as far as I can tell. Here is the problem.
When I go into setup>folders. I try to change the Temporary download directory from the default to the new directory I created. I use the browse button and navigate to the directory. '/mnt/working/temp'. It seems to be fine. I hit save changes and I don't seem to get errors. BUT if I navigate to a different tab and then back to folders. It is set back at the default. Any idea what I could be doing wrong?
