New temporary system that is working fine.  Using it for Plex and backing up my accounting software.
System consists of the following,
FreeNAS 11.1-U6
Intel i5 CPU 661@3.33GHz
8Meg of Memory
4 8TB WD Red drives in a Z1 configuration
2 3TB WD Red drives in a striped configuration
1 SSD 120GB boot drive
1 SSD 240GB drive for Jails
And yes I know that the base system is far from what I should be using but money is tight and so I set this up as temporary and to help me learn freenas. When I have put enough money aside I will post a request to get advice on used equipment recommendations.
All drives seem to be working fine and the Plex setup has about 6.5TB of data.
Email works fine when tested and SMART and Scrubs have been setup.
When I go to Services and try to turn on S.M.A.R.T., is will not turn on but does not display any error message.
I have searched the forum but have not found anything what works. The only things I have found seem to only apply if you use a USB as a boot disk and that is not the case here. I will keep searching but so far have had not luck.
All I can figure is there must be a setting that I am missing. Is there a setting that tells the S.M.A.R.T or Scrubs tests to send reports or just a daily report?
Any help will be greatly appreciated.
FreeNAS 11.1-U6
8Meg of Memory
