Hi guys
I'm fairly new to FreeNAS and messed with it a while ago. I'm expanding my disks and figure it would be a good time to redo the setup and do it the right way this time. After spending a lot of time reading about best practice i realize that the way i set it up before wasn't the best way.
Now i got to the plugins. Before i installed the plugins through the GUI and now see that it might not be the best solution if I always want to have the newest version of a plugin (Plex pass).
This time i'm going to do it manually with the pkg.
This leads me to the actual question. I see that some people prefer to have all the plugins in a single jail. Is that best practice or just a matter of preference? I can see the benefits of having everything run on the same IP. Is there other pro's / cons with this?
If i were to go this route, how should i approach this when creating the first jail?
Hope you guys can clarify this for me. Thanks in advance.
