SOLVED Rsync tasks piling up
michen
Hello dear forum members,
recently my FreeNAS Server seemed very unresponsive and slow when accessing it through Windows Share (SMB) and then via the Web Interface.
Upon closer investigation I found a bunch of accumulated rsync tasks driving the system into full load. I took a screenshot of top:
I configured rsync as a cronjob, and it is supposed to run every 6 hours to mirror the whole dataset to an offsite backup server.
I should maybe add that it has worked stable for quite a while now and this is the first time the problem occured.
The most recent change to the system was an upgrade to the most current version (FreeNAS11.1-U7).
The system configuration is:
  • ASUS P5B Mainboard
  • Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
  • 8192 MB RAM
  • Stack of 11 WD Red Series, 3TB each
  • onboard RAID, additional PCI Controller
  • onboard Intel Network Controller
Does anyone have a clue what could be the cause?
Regards,
Michael
michen
I dug into this a little more and found out that the tasks did not finish their job, i.e. there was an error message from rsync that I did not catch in the logs. I took a dry run from the command line with the same commands that are in the cronjob and the following error came up:
rsync: write failed on "/mnt/syn112/rsyncback.log": No space left on device (28)
rsync error: error in file IO (code 11) at receiver.c(400) [receiver=3.1.2]
rsync error: error in file IO (code 11) at io.c(1633) [sender=3.1.2]
Thing is, there is more than enough space on the destination drive. Further investigation led me to believe that I was missing the --inplace option with rsync. But then again, logic dictates that if it hadn't been ever necessary before to feed rsync with --inplace the original cause must be something else. However, I am now dry-running rsync with that option to see if it helps.
Anyone else have a clue what is going on?
michen
Okay, I finally found out the cause of the problem. The rsync destination folder was not mounted as a SMB share.
It was treated as a local directory on the system partition.
That happened because of the reboot (update & restart), and the fact that I did not automatically mount the SMB share upon reboot.
I fixed this through the web interface by adding the mount command as a post-init command (Menu->Tasks->Init/Shutdown Scripts).
That should avoid the problem for future updates.
