Rsync Task: How to specify different remote username?
jbee
I want to sync my FreeNAS box with a remote Linux server. Although I put the keys where they belong on both sides and was able to establish an SSH connection manually, the task still throws a
rsync: Permission denied (publickey,password).^M
in the log. I suspect that this is because the local user running the task has a different name than the remote account. How/where can I specify the remote username?
Dusan
You can't. You have to use the same username on both systems.
fracai
You could always write the rsync task as a CRON job instead. Then you could specify the local user to run and the remote user to connect as.
