rsync task auxiliary parameters syntax
iVhksqJjo
I'm trying to make an rsync task that only syncs folders with "-config" and all their subdirectories and files, and so I input the necessary parameters into the "Auxiliary Parameters" fields on the rsync task.
For instance if I input:
--include '*-config/**'
that is seen as 2 different params because of the space.
So then I do double quotes around the entire statement:
"--include '*-config/**'"
But now the rsync task fails when run.
What syntax am I supposed to use to get my params to work?
jgreco
Resident Grinch
You can try reporting it as a bug but I'm not sure there's a good fix for this. rsync allows some very bizarre parameters and while your specific case should be fixable, I can imagine a number of slightly more complex ones that won't be.
What about if you try it like this:
--include='*-config/**'
Fails immediately, like the double quotes with the space preserved.
:frown:
Last idea I can think of:
--include=*-config/**
Quotes removed. (Maybe the GUI wraps parameters in quotes under the hood?)
Nevermind. I just read the tooltip.
Note: The "*" character must be escaped with a backslash (\\*.txt) or used inside single quotes ('*.txt').
I wonder if this will work then:
--include=\*-config/\*\*
iVhksqJjo
:frown:
When inputting your suggestion, saving and then opening the task again, this is what truenas has parsed it to:
However, it doesn't fail outright. The task runs, but nothing happens (ie. no data is transferred) :confused:
Screw it, let's try a hail mary then, if TrueNAS wants to play hardball.
--include='\*-config/\*\*'
Or the double-quote version (if the above doesn't work):
--include="\*-config/\*\*"
iVhksqJjo
The single quotes are parsed into double quotes automatically:
... But now it just fails immediately :frown:
Lately I've been frustrated with the lack of polish and practicality of using the GUI on this NAS "appliance". :confused:
Last idea I can think of before giving up:
--include-from=/path/to/file
Then just use an "include file" that contains the content:
*-config/**
EDIT: On second thought...
...this might have "worked", but the pattern is incorrect?
iVhksqJjo
*-config/**
My pattern is definetely poop, as it returns things I don't want, when I just the rsync command from the truenas terminal - but it is returning data, which I cannot get truenas to do through the gui, unless I target just 1 path and try to sync everything, without params.
I also tried just adding multiple paths into the remote path thinking I could just add a path for each of my -config folders:
/source/dir1-config/ /source/dir2-config/
... But that also fails despite the fact it works perfectly in the when I use rsync on those dirs in the cli
rsync -avz user@ip:'/source/dir1-config/ /source/dir2-config/' /destination
So it seems the rsync gui only accepts 1 path, which is really frustating...
So I guess I just have to make 20+ rsync tasks via the GUI, one for each of my dirN-config on the source until the functionality is made usable from the gui. Or alternatively put a script somewhere with all the dirs included that's executed on a cronjob, if I can't find a working pattern.
Richard Kellogg
I'm using truenas core 13.0, i had similar issue. The method for adding additional ‘rsync options’, is on the Auxiliary Parameters. However, after typing in a single option, you press “enter”. This puts the optional text inside a bubble. To add more options, you continue to add the option text, followed by another “enter” key. This adds a second bubble. And so on, for additional options.
It’s actually in the manual, but I hate how the gui keeps getting changed for arbitrary reasons, that just make for operator screw ups, with little to no value added.
