Agent92
- Feb 11, 2019
When I run the following command from the command lines as root everything works as it should, all the excluded directories are excluded:
But when I run it using a cron task I create in the FreeNAS interface suddenly my excludes doesn't work, it starts to copy for instance the content of /proc. I have chosen to run it as the root user when I created the cron task so I'm not sure what would be different that could cause this. Does anyone have any idea?
This is from the log when it starts to copy /proc.
I know it says "proc" not "/proc" in the log but it did that when I ran it from the command line also.
I'm running FreeNAS 11.3-U1.
/usr/local/bin/rsync --rsync-path="ionice -c 3 nice -n 12 rsync" -aS --delete-excluded --address='10.30.1.2' --log-file='/var/log/rsync.log' --exclude={/usr/share/cagefs-skeleton/*,dev/*,/proc/*,/sys/*,/tmp/*,/run/*,/mnt/*,/media/*,/lost+found} remote.server:/ /mnt/local/backup/folderBut when I run it using a cron task I create in the FreeNAS interface suddenly my excludes doesn't work, it starts to copy for instance the content of /proc. I have chosen to run it as the root user when I created the cron task so I'm not sure what would be different that could cause this. Does anyone have any idea?
2020/03/28 19:23:25 [4700] >f+++++++++ proc/buddyinfo 2020/03/28 19:23:25 [4700] >f+++++++++ proc/cgroups 2020/03/28 19:23:25 [4700] >f+++++++++ proc/cmdline 2020/03/28 19:23:25 [4700] >f+++++++++ proc/consoles
