Hi All,
TrueNAS CORE 12.0-U7
I have a dataset that is set to ACL Mode: Passthrough
I connect via windows 10 cifs drive letter, copy some files and folders to /src and verify the permissions
I use the local TrueNAS rsync application to copy files from src/* to dst/
rsync -avr -o -g src/* dst/
What I see is the "folders" in dst/ have correct permissions but the "files" do not and generate this error when viewing the security properties on my windows 10 machine:
The permissions on file xxx.yyy are incorrectly ordered, which may cause some entries to be ineffective.
what I see is :
"Everyone" now has Special permissions
"wheel" now has Special permissions
all other permissions are the same
Is there a known way to fix this, I assume if I use an "rsync module" as the destination I will have the same error.
Thanks,
Joe
what I see is :
Thanks,
Joe
