I'm trying to run this using a bash script to start a replication task:
But the job created by this seems to fail and running
What am I doing wrong? Do I need to pass more data or something like that? I just want the replication task to be run like if I press the "run now" button in GUI but using CLI instead.
curl -s -k --netrc-file "/path/to/my/netrc.file" -X POST "http://192.168.0.1/api/v2.0/replication/id/39/run" -H "accept: */*" -H "Content-Type: application/json" -d "{}"But the job created by this seems to fail and running
#curl -s -k --netrc-file "/path/to/my/netrc.file" -X GET "http://192.168.0.1/api/v2.0/replication/id/39" -H "accept: */*" -H "Content-Type: application/json" | jq shows me job details like this:Code:
"job": {
"id": 49215,
"method": "replication.run",
"arguments": [
"39",
"logs_path": "/tmp/middlewared/jobs/49215.log",
"logs_excerpt": "",
"progress": {
"percent": null,
"description": null,
"extra": null
"result": null,
"error": "[really_run] Not a boolean",
"exception": "Traceback (most recent call last):\n File \"/usr/local/lib/python3.7/site-packages/middlewared/job.py\", line 349, in run\n await self.future\n File \"/usr/local/lib/python3.7/site-packages/middlewared/job.py\", line 385, in __run_body\n rv = await self.method(*([self] + args))\n File \"/usr/local/lib/python3.7/site-packages/middlewared/schema.py\", line 960, in nf\n args, kwargs = clean_and_validate_args(args, kwargs)\n File \"/usr/local/lib/python3.7/site-packages/middlewared/schema.py\", line 918, in clean_and_validate_args\n value = attr.clean(args[args_index + i])\n File \"/usr/local/lib/python3.7/site-packages/middlewared/schema.py\", line 374, in clean\n raise Error(self.name, 'Not a boolean')\nmiddlewared.schema.Error: [really_run] Not a boolean\n",
"exc_info": {
"type": "Error",
"extra": null
"state": "FAILED",
"time_started": {
"$date": 1611424535462
"time_finished": {
"$date": 1611424535465
}What am I doing wrong? Do I need to pass more data or something like that? I just want the replication task to be run like if I press the "run now" button in GUI but using CLI instead.
