PhiloEpisteme
Neophyte Sage
- Oct 18, 2018
PhiloEpisteme submitted a new resource:
Reusing Encryption Keys & Passphrases - How to reuse your encryption keys and passphrase when you replace a pool or replace a drive
Read more about this resource...Let's get the messy bit out of the way. This resource makes no claim about whether you should or should not use encryption. Discussion on the merits or implementation strategy used in FreeNAS is not relevant to this resource. I'm not looking to advocate for or against encryption.
This resource is intended as an instructional guide for folks to follow as an educational tool to learn more about FreeNAS encryption in a specific use-case. Whether you are comfortable reusing the keys and...
