James Nicholas
 - Apr 30, 2017
I have a hot spare that automatically joined my pool when I had a faulting disk. I have since replaced the disk. The resilver completed successfully. The spare stayed joined. I have since re-replaced the faulted disk, and the spare, and the join persists. As per the instructions I found here: https://www.truenas.com/community/threads/how-to-return-hot-spare-to-spare-status.94407/ and corresponding detail on page 52 here: https://illumos.org/books/zfs-admin/zfs-admin-ebook.pdf
I have dried detaching the spare, the command fails with the following:
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 243, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 94, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 235, in detach
self.__zfs_vdev_operation(name, label, lambda target: target.detach())
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 226, in __zfs_vdev_operation
op(target, *args)
File "libzfs.pyx", line 391, in libzfs.ZFS.__exit__
op(target, *args)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 235, in <lambda>
File "libzfs.pyx", line 2070, in libzfs.ZFSVdev.detach
AttributeError: 'NoneType' object has no attribute 'type'
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1062, in detach
await self.middleware.call('zfs.pool.detach', pool['name'], found[1]['guid'])
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1221, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1227, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1154, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
In short, I have a RAIDZ2 Pool, with a spare active, that doesn't need to be active. How can I return it to being an available spare?
op(target, *args)
op(target, *args)
